Flail mower required HP question
   / Flail mower required HP question #1
DennisH
Huntsville, AL
So I'm in the market for a Flail mower and have been looking hard at the Caroni TM1900 which is a 6' mower rated at 30-60 HP and weights 650 Lbs.
I have noticed that all flail mowers irregardless of brand start out at minimum 30 HP ratings.
My JD 870 is rated at 28 HP so the question is will a flail mower work behind this tractor?
   / Flail mower required HP question #2
my 2520 is like 25-26 HP.
I have a 5 foot flail on it, and it works great, but it struggles a bit in really tall thick grass. I would put a 5 footer on your tractor, unless you only plan on cutting thin dry easy cutting grass. Mine is river-bottom, and flood plane, so it cuts hard as heck. I'd never be able to turn a 6 footer, muchless carry it. :laughing:
   / Flail mower required HP question #3
I don't know if this will help or not, but I pull a 90" cut 1250lb. flail behind a 49HP, 37 PTO tractor and it does it pretty easily.
   / Flail mower required HP question #4
I have a TM1900 on a 41hp Kioti. I would certainly consider using a TM1900 on a 28hp tractor for routine and regular pasture mowing etc. I would probably not use it on that size mower if my main task was bush hogging or once per year pasture mowing unless I was willing to go slower. I have no doubt that 28hp is basically OK as I run my 41hp tractor about 400-500 RPM below PTO speed most of the time and it cuts fine. I'd guess the tractor is putting out low thirties HP for most of my mowing.
   / Flail mower required HP question #5
Hey DennisH,
I have a 5ft Alamo Flail mower on my JD790 which is rated at 27 hp. It does a great job and I can make some pretty good time with it. In the thick stuff, I sometimes have to go slow.
If you're going to keep ahead of the growth, I'd think a 6ft would work just fine. If you're going to be knocking down brushy type stuff, you'll be going slow anyway.
TommyJD790
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
