flail mower, hammer mower?
   / flail mower, hammer mower? #1
wikidsupra87
Picked up a mower, looks like a rototiller. Owner says it's a Woods 5ft. It is 5ft but all the stickers and placards are gone. Is there a website with pics that I could use to identify the mower. Thanks Eric.
   / flail mower, hammer mower? #2
Post a picture on here and give us a try. Do a search for Woods 5 ft.
http://www.woodsequipment.com/default.aspx
Since you said it looked like a tiller, then it must be a flail mower.
http://www.woodsequipment.com/flailshredders.aspx?id=10495&ekmensel=ff8c4a46_21_0_10495_3
   / flail mower, hammer mower? #3
I just looked at their web site and only found much larger flail mowers. Or they call them flail shredders. But they could have had 5 foot and dropped it or I just missed seeing them.
   / flail mower, hammer mower? #4
the flail mower shredder will have serial numbers stamped on it and the gear box or a plate with all the information identifying it look on either side of the mower or under the cover where the belts are located on the side.
The beauty of flail mowers is balance, knives that fall away if they impact something and zero worries about throwing something while mowing.
Another plus is being able to mow wet grass too with lots of power.
The side bearings will be easy to replace and find anywhere as well.
The main bearings in our Matthews flail mower lasted for over 20 years before they required replacement
If the V belts are at all checked/cracked they need to be replaced.
Buying the Gates green heavy duty belts is money well spent as they will last a long time and hold up very well.
You will not have any trouble finding hammer knives or mower knives for the mower either as they are all standardized by size.
I would contact woods directly or the local Woods dealer and spend some time talking about your mower to obtain a manual for the unit so you have part numbers.
leon
   / flail mower, hammer mower? #5
Good info leonz, I am thinking about a flail myself, and I was wondering if they are ''stump jumpers" and also how big can they shred. I am wanting to clear and keep clear my land of the small oak, cherry, etc saplings that spring up each year. This is in an area that I had clear-cut in 2007. tks
   / flail mower, hammer mower? #6
If you had land clear cut in 2007 then even a moderate duty flail should have no trouble with subsequent growth. The stumps are a different issue. Flails don't have "stump jumper" plates like bush hogs. A flail will therefore try to cut into a tall (greater than about 4-6 inches off the soil) stump (it might stall the tractor) and it is possible that the stump will snag the trailing roller tube that all flails have which could easily result in significant damage (banana shape) of that roller. On the other hand, if the stumps are just a few inches high then the flails will simply whack at them and roll over without any real drama.
   / flail mower, hammer mower? #7
Island,
what does that rear roller really do? i don't understand the reason for it.
thanks
   / flail mower, hammer mower? #8
Island,
thanks
Basically it determines your cut height. A flail can be operated with the rear roller off the ground by using the 3pt hitch to adjust height of cut but to get the most even cut it is best to lower the 3pt arms until the rear roller takes the weight of the mower and then adjust the angle of attack with the topping lift which gives you some fine control over cut height. The mower essentially pivots on the rear roller so it cuts a more consistent length of grass. The roller height has some adjustment in ti but it is not the sort of thing you would fiddle with each time you mow. Same basic principle as having most of the mower weight on the wheels of a finish mower or bush hog rather than having it raised in the air controlling cutting height only with the 3pt.
As noted, you can run the mower perfectly well with the roller off the ground but you will not get as low a cut and you will not get as smooth a cut (the mower will raise and fall depending on the tractor). It does make sense to use the mower with the roller off the ground if you are indeed cutting in an areas with unknown stumps/rocks etc with the idea that you can get a first pass cut down to 6-8 inches or so and then, once you've identified the size objects that you might roll over with your tractor but would still snag the rear mower roller, you can then lower the roller and mow around those objects safely.
   / flail mower, hammer mower? #9
island, so when i cut with my flail, which is a caroni i leave v shaped marks in the dirt when i mow that would mean i should lower the rear roller. i have been using the 3ph to adjust height to avoid it but by lowering the roller i should be able to lower the 3ph all the way down and not get that v in the dirt. if that right i think i'll go and adjust it for the next time i cut.
thanks
   / flail mower, hammer mower? #10
What do you mean about the[ V ] marks in the dirt. Your flails should not be touching the dirt. The roller is designed to keep you from scalping hills. Do you have pictures of your flail digging in.
2012 Mazada 3 Sedan (A51694)
2012 Mazada 3...
Unused 2025 Pure Electric Cart (A51694)
Unused 2025 Pure...
2021 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A53843)
2021 ALLIANCE...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
