Fixing a leaky FEL cylinder
   / Fixing a leaky FEL cylinder #1
Wheeldog
NW CT
Kubota B2410HSD
Well it looks like I've got a bad seal on one of the bucket cylinders on my loader. I noticed fluid gathered at one corner of the bucket so I took a closer look and there was fluid on the polished part of the left-hand cylinder. I'm a little surprised because the tractor/loader are only about 3 years old. Anyway, I don't know what I'm looking at here. Can I replace the seal? Is removing the cylinder pretty straightforward? /forums/images/graemlins/confused.gif
   / Fixing a leaky FEL cylinder #2
Replacing the seal is fairly straight forward...but run the arm completely out and check with a straight edge...usually when the seal goes the arm is bent...I replaced the seal on mine 3 times before I thought to check the arm...had to take it to the Hydraulic shop to have the arm straightened....cost $100 to straighten and rebuild the cylinder..
GareyD
Garey,
Thanks - I'll check the rod to see if it's bent before I go any further.
- Rob
2016 Freightliner TMA (A52377)
2016 Freightliner...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
9202 (A50322)
9202 (A50322)
7033 (A51691)
7033 (A51691)
20 ft. Shipping Container (A53117)
20 ft. Shipping...
