FIXED - Vague control feeling in BH77 Backhoe
   / FIXED - Vague control feeling in BH77 Backhoe #1
Dexterous
Grove City, PA
2019 Kubota B2650
Guys,
I recently purchased my second Kubota, a brand new 2019 B2650 with the BH77 backhoe. My previous machine was a fairly new, 2017 BX23S. I purchased both machines primarily for the backhoe to do ditch work around my property so I have lots and lots of prior backhoe experience at this point.
The old BX23S backhoe felt really good but the new one felt really vague and inaccurate. Needless to say, I was very disappointed with the poor feel of the BH77. However, after watching a number of videos and reading a few things on various forums, I learned how to inspect the control linkages and I discovered why I was having the problem. Imagine my surprise when I discovered that the control links inside my new B2650/BH77 with less than 15 hours were ready to fall apart!
I made this video so that everyone could see exactly why I had this issue and how I fixed it. Thanks!
   / FIXED - Vague control feeling in BH77 Backhoe #2
The handles in my ZTR are the same concept and they work loose sometimes. Really it would benefit from a complete linkage replacement because the “ball joints” are worn out. The previous owner sold it cheap because he thought a drive motor was failing.
   / FIXED - Vague control feeling in BH77 Backhoe #3
Very good. I’m used to mine and is third BH I’ve had, but I’ll have to check it out. I had mine apart about five years ago when new to replace a prv and now that I see your post it seems I recall those bolts being not snugged down.
What loosened mine up a year or two ago was jumping off and my shorts caught on one of the control levers and bent it! I just grabbed it low and bent upper portion back. Another reason to check it...thanks for post.
btw, Your machine looks nice and clean!
LOL, it’s still new. I power washed it to work on it but that’s about it. I kept the old machine pretty clean when it wasn’t being used just because they are so much easier to work on when they are clean.
   / FIXED - Vague control feeling in BH77 Backhoe #5
Checked out the linkages on my 2017 BH77 (on B2650) after seeing your post and sure enough 3 of 4 lower links were loose. The right hand pair - bucket/dipper - were very loose, I took them off easily by hand. Cleaned, thread-locked, and re-tightened, now the controls have much better feel.
Thanks Dexterous!
   / FIXED - Vague control feeling in BH77 Backhoe #6
Thanks for sharing.. I have a 3pt backhoe for my Kubota and I have not been satisfied with the controls.. will need to take a look and do some maintenance.
2013 COACHMEN CATALINA TRAVEL TRAILER (A50854)
2013 COACHMEN...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
INGERSOLL RAND COMPRESSOR (A50854)
INGERSOLL RAND...
Bus (A50323)
Bus (A50323)
