3-Point Hitch fix for 4400 3PH
   / fix for 4400 3PH #1
BCinVA
Bronze Member
Southwest Virginia
Kubota MX5400, JD 655, JD 535M, JD425, Exmark Radius S zero turn (Previous JD 4400 HST)
I was having problem with 3PH on my 4400. It would bog the engine when in the full up position. It was difficult to position anywhere but full up or down. I found that the roll pin on the feedback arm that runs between the hydraulic control valve and the left side lift arm had sheared. On further inspection I found that the reason it sheared was because the shaft it attaches to and runs into the hydraulic control valve was frozen and would not turn. After some time and much disassembly I was able to get the shaft freed up and the roll pin replaced. The hitch works fine now. If anyone has this problem, this would be a good place to look. It is very difficult to see this problem because everything looks like it is working. I only found it when I removed the cover from the hydraulic control and saw that when the rod moved outside nothing moved inside.
Root Grapple (A50322)
2015 DODGE RAM...
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A52128)
2019 Ford F550 4x4...
