Thumb First use of the thumb.
   / First use of the thumb. #1
gray
Upper Peninsula of Michigan, on the shore of Super
Kubota L48 tlb
Yesterday I welded the thumb on my BH. It is a mt830 from Excavator thumbs.com. I had little trouble mounting it and trimming about 2 inches off the jaws to fit the bucket better.
I used it today lifting dead fall loags out of a drainage ditch today. It will take some getting used to and right away I did feel a hydraulic one would be even nicer. It performed well and allowed me to reach down into the ditch about 4 ft. below grade and lift many large logs out. I also used it to grapple 5 small 3 inch maples and lift them right out with little ground disturbance and very fast results. Much more to do with it before I report any other pros or cons.
The unit is well built and heavy. Some observations on it's design: It does not need a 2 inch pin at the pivot- just adds weight. It could use more of an angle option than the about 115* it has- a 145* would find more functions.
Hair type or flip over type keeper pins shoud be used for the main pin retainers rather than the bolts- faster and easier no tool changes.
I am looking forward to using this thumb and finding many other uses.
Would like to here from others on pros and cons as well as creative uses they may have found.
Oh yes, I will try to take a digital picture and post it. Not something I know how to do at this time. I do like to see the pictures others have taken and should post some of my own if I can manage to figure out how. /forums/images/graemlins/grin.gif
   / First use of the thumb. #2
I'm considering the hydraulic thumb from werk-brau, do you know anything about them? I sure with I had the mechanical aptitude to do my own work as you guys do /forums/images/graemlins/tongue.gif
I have not heard of the Manuf. of that thumb? I did look into CDP kits and MC Faulkner Welding as well as Excavator Thumbs before I got the one I did. There are many out there. I just rolled the dice and feel it worked out OK for the unit I got.
I did not want to invest in the additional hydraulics at this time to run a hydraulic thumb. That may still happen in the future.
Is there a web site to veiw this thumb you are thinking of. I would like to see it.
Sorry, I have no info for you on your thumb question.
   / First use of the thumb. #4
Gray, yes, the website is www.werk-brau.com They have quite a selection of attachments. My dealer says that they equip the Kubota excavators with thumbs. I guess it's quite a wait to have them put a kit together...Tony
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
2803 (A50460)
2803 (A50460)
Wolverine Slide on Manure Forks (A50515)
Wolverine Slide on...
2004 JOHN DEERE 310SG BACKHOE (A51242)
2004 JOHN DEERE...
International 820 Platform (A50514)
International 820...
