First Transmission Fluid Change
/ First Transmission Fluid Change #1
stormking
Tacoma, WA
I'm about to do my first trans/hydrauliic fluid change on my 2004 L3130 and the picture in the manual is confusing. I found the two drain plugs on each outer side of the rear axle, but I'm not clear whether there are two or only one drain plug directly under the main trans. I can see one obvious one, but the manual seems to show another one farther forward?????
/ First Transmission Fluid Change #2
I have about 25 hrs on my 2006 L3130 HST and after crawling under my tractor getting ready for the soon to come fluid change I found the 2 drain plugs for the transmission:
A 24 mm drain plug and a 10 mm recessed hex socket drain plug.
Hope this helps.
Rob
2019 KOMATSU D51EX-24 CRAWLER DOZER (A64279)
2019 KOMATSU...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
2022 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2022 ASV RT-25...
2019 UTILITY VS2DX 53' X 102" T/A VAN TRAILER (A59912)
2019 UTILITY VS2DX...
