First Tractor Experience. (long)
   / First Tractor Experience. (long) #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
After two 12 hour days in the seat of an old Massey 135 playing with a disk, box blade, home made drag and brush hog I am one tired and sunburned puppy. I did get about 1/2 acre leveled but not cleaned or finished and cut about 5 acres of 2 foot tall prairie grass. The tractor, disk and brush hog belongs to my neighbor and is in dire need of a trip to the shop.
The ground cable from the battery was broke so to start it he would open the hood and hold the wire to the frame while he hit the starter button. The PTO lever won't stay engaged so a piece of bailing wire holds the lever in place when you engage the PTO, same with the lever that raises the 3 point hitch arms. The 3PH arms seem to drift but that could be because the control lever flops around. Not complaining mind you because the price to use the tractor was right and I was even using his fuel. I did fix the battery cable for him.
Even with things not working quite right I managed to get what I felt was pretty good with the box blade. Managed to level about 1/2 acre well enough that it looks flat and if I can get rid of the grass clumps it's going to be about perfect.
Today I went to Atwood's and bought a landscape rake, don't own a tractor yet but by-golly I own a landscape rake. Am hoping I can figure out how to use it well enough to finish the grooming of my flying circle and clean up the drive a little.
Running the bush hog was an experience in patience, I could only cut in low gear, low range without the tall grass bogging down the engine and even then in the really thick stuff I had to do some fancy clutch work to keep it from stalling.
I have many thoughts and lessons learned but I now know that when I get ready to buy my own tractor it will be something with some horse power and a shifter that doesn't take an ordeal just to change from 1st to 2nd.
But all in all... Ya I had a good weekend and feel a pretty good sense of accomplishment.
   / First Tractor Experience. (long) #2
From the description of the rest of his equipment, the blades on the bush hog are probably original and Dull as can be. At a minimum, sharpen them, or buy some new ones for him (and you).
In cutting tall grass, make sure it is DRY with that set up. It needs all the help it can get. Or, set the blades to cut it taller and make two passes, lowering the unit on the second path.
Stay safe.
Ron
Thanks for the tip on the blades for the bushhog, I will see what I can do..
Hooked up the landscape rake this morning and spent a couple of hours playing with it. Man I have to tell you next to the boxblade that is about the most useful implement I have found so far. Still have to go over the area a couple more times but it sure is looking pretty darn good right now. I can visualize using this thing for all kinds of stuff, as soon as I finish the circle I am going to start on the gravel drive.
   / First Tractor Experience. (long) #4
I used to hog a couple of acres for a neighbor with my TO20 - one time in the spring it took me a little while to get to it, and it had gotten quite long. I tried to pull it in 2nd, then 1st, and eventually I took it home as I was convinced that it was out of tune. I didn't find anything wrong, but I did notice the blades needed a dressing. When I got back, it cut like butter. Dull blades really do increase the load on the tractor tremendously. Given the state the rest of the tractor is in, I would bet it is in need of both a tune up and blade sharpening! I don’t know how big a brush cutter you were running, but it seems to me that a MF135 in good shape should not have much trouble with a cutter, at least up to 5’ anyway, and even a 6' if it you don't push it. I've run a 5’ on my TO20 for years with no problems, and that is considerably down on power from a MF135.
An MF135 may not be what you'd really want, but it is a pretty capable machine, IF it were in good shape. I would be careful with it though!
</font><font color="blue" class="small">( I would be careful with it though! )</font>
You said that right, if it ever had any safety features like not being able to start in gear they have long since been defeated. No ROP's, no PTO cover and you can stick a finger through holes in the rear tires and touch the inner tube.
Although it does say something about these old tractors, this one has over 3000 hours on the clock with what looks like little or no maintenance and it's still running.
2025 CFG Industrial MX20R (A50123)
2025 CFG...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
Caterpillar 259D (A50123)
Caterpillar 259D...
