First Time Tractor Owner LB1914
   / First Time Tractor Owner LB1914 #1
Geoscouter
Mid Missouri
Kioti LB1914
I recently purchased a 1999 LB1914 with loader(Buhler-Allied), Rear finish mower and rear blade. It has 302 hours. Still learning how to operate it but seems fairly straightforward. The only problem encountered so far is the High / Low gear range lever is very hard to move. Is there any way to lossen up this control? Also, in the manual it refers to a Fuel Thermistor on the control panel ..looks like an idiot light. What is a fuel Thermistor?
In looking at the Sevice Interval chart in the Maintenance section of the manual I'm a little confused. It lists hours and Date to perform the service. For example in one row
Hours Date Replacement Perform
First 50 6 months Engine Oil and Filter Grease, Inspect Fluid levels etc
Transmission Oil and Filter
Does this mean to do it either at 50 hours of operation or 6 months whichever comes first? The reason I ask is that further down on the chart there is a section called Low Usage. The row in question is:
Low 300 2 years Transmission Oil Adjust valve lash (Contact Dealer)
Usage and filter cleaning
Front axle gear oil
What is Adjust Valve lash? Since this tractor has just reached 300 hours but is 8 years old should I assume that it was done by the previous owner. I bought from the second owner who had it only 2 years. Can I do this myself or is there a way to tell if it has been done. Does it have to be done every 300 hours of operation?
Sorry for all of the questions but would appreciate any feedback. Like many I've been reading this forum for many years but am just now posting. I'ts been a real education for this city boy who now has some rural property and now a tractor.
   / First Time Tractor Owner LB1914 #2
Your better off getting an answer from Wallace or someone more knowledgeable, but here's my answer.
50hrs or 6 months is which ever comes 1st. You're way past that. ;)
Adjust Valve Lash is done on the motor. The odds are you won't need an adjustment, but you might want to have them checked. You probably can't tell since it's new to you, but if valves go out of alignment, the motor will sound different. Because you don't want to run a motor that's not in spec, you want to get them checked and have adjustments made as needed.
As to guessing about maintenance by the previous owner.... If you're going to assume, assume they never did a dang thing other then fuel it up and use it. On a used vehicle of any type, I always like to change out all fluids and filters when I get my hands on them.
Now go and enjoy your new toy.
(4) 12-16.5 NHS TIRES & RIMS (A51243)
(4) 12-16.5 NHS...
John Deere 2020A Progator (RUNS) (A50774)
John Deere 2020A...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
Onsite begins 8:30am / Online begins 9:30am (A50120)
Onsite begins...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52748)
NEW 2022 Load...
