First Service for 7520
   / First Service for 7520 #1
zubin6220
I was just hoping for some feedback on when you did your first service. I see that oil is recommended to change at 100 hours and not 50. Transmission filter is recommended at 50 hours. Am I reading the initial service incorrectly? Also, the 'service' buzzer now comes on when starting with a service warning light. How does one turn off this buzzer. btw - I have had no problems at all with my new tractor and am very satisfied.
Thanks in advance for your comments.
   / First Service for 7520 #2
Zubin,
I have a 6520. Which is very much like your 7520. In my owner's manual, it has a # at 50 hours for change oil and filter element. At 250 it has a black square. So I R&R'd the oil and filter at 50 hours and will do it again at 250 hours. I also changed all the transmission filters at 50 hours, along with the powersteering filter.
On the light and buzzer, open your hood. Just above the latch you pull to open the hood is a fuse box. On the right side up high on the fuse box is a little box with a cover on it. It is about an 1.25 inches wide. Open the cover, put your key switch on to the "IG" position. Wait 10 seconds then short circuit the terminals. This should turn off the maintenance reminder buzzer and light. This is how it is done on the 6520. :cool: I am not completely sure it is the same on the 7520. When in doubt, ask one of the dealer's on this forum or ask your mechanic.
hugs, Brandi
   / First Service for 7520 #3
zubin6220, this is the 50 hour list that I have.
check coolant level and add as needed
check radiator hoses and tighten as needed
check fan belt and tighten if needed
check transmission oil and add as needed
change transmission oil filter
check tire pressure and inflate as needed
torque lug nuts
change hydraulic oil filter
clean hydraulic suction strainer
change power steering filter
grease all grease fittings
bindian has the procedure shown to stop the service buzzer.
Thanks all for the information, I'll get on it right away.
When you mention to change the transmission oil filter and the hydraulic oil filter - doesn't this require a complete drain first or can you just replace the filters without draining?
Thanks again
   / First Service for 7520 #5
Thanks again
Change filters only, no problem.
Unused 2025 CFG MX20R Mini Excavator (A50322)
Unused 2025 CFG...
AYLEID HOSE REEL, SPRINKLER (A51244)
AYLEID HOSE REEL...
2016 GMC Sierra 1500 SLT 4x4 Crew Cab Pickup Truck (A50323)
2016 GMC Sierra...
2019 Harley Davidson (A50324)
2019 Harley...
UNUSED FUTURE 32" HYD TILT MINI EXCAVATOR BUCKET (A51244)
UNUSED FUTURE 32"...
