First Request - 3 PT Hitch Spreader
   / First Request - 3 PT Hitch Spreader #1
Amsbrook
Milford, CT.
Kubota BX2200
Anyone have any experience with a 3PT hitch spreader (i.e., how effective they are, what size, etc.). I have a "new" pull behind that I used in the past with my old tractor but the idea of having it as part of the tractor (& PTO driven) makes a lot of sense. I will use it for pelletized Lime and fertilizer (6~8x/Yr.) for 2 acres of lawn. Any advice would be greatly appreciated.
Thanks,
Jim
   / First Request - 3 PT Hitch Spreader #2
I've had one for 3yr's, I bought it at {Farm&Fleet} work's great. Payed around 300 was at the store last week, they'er 350 now. It does a very good job with throwing, a pattern. I use the pellet lime every spring. When I'am done with it I wash it out real good and spray it down with 2 full can's of WD-40 and it still look new!!!
Camshaft in Pa.
   / First Request - 3 PT Hitch Spreader #3
I bought a 3 pt spreader last year. I love it. It's a Tru-Flo and holds 500lbs of whatever. Load up the hopper and off you go.
Clean up, as Camshaft said, is the key. When I'm done I wash it out really well and then oil and grease everything.
Bill Cook
   / First Request - 3 PT Hitch Spreader #4
Jim,
Just started using the broadcaster that LandPride has and it seems to work great. I spread 3.5 tons of powdered lime last saturday, 700#'s at a time, and it seemed effortless. The broadcaster seems very well built and it performed better than I expected. The powdered lime is probably about the hardest material there is to spread and it spread 700#'s in about 45 seconds. I purchased the larger size and it was around $475 through my dealer. You can look it up at www.landpride.com.
Jeff...MI.
2016 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2016 Ford F-450...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
2012 Dodge Grand Caravan Van (A50324)
2012 Dodge Grand...
Wooden Dump Barge Wagon (A50515)
Wooden Dump Barge...
Kubota SVL95-2S Compact Track Loader Skid Steer (A50322)
Kubota SVL95-2S...
