first repair
   / first repair #1
mudcat
Platinum Member
North Central Florida
I have been working the tractor pretty hard the last couple of days. Today, while ripping out some roots on a pine tree I plan on pushing over, I noticed some fluid dripping off the cross brace of the loader.It was coming from a hard line fitting, the second one from the front. To my surprise the nut was loose. Is it common for hydraulic fittings to work loose? The tractor has 60 hrs on it.
   / first repair #2
No, it is not common for the fittings to work loose, however, it is not uncommon for anything assembled by a human to develope a leak---due to human error during the assembly process. (Someone probably did not get it completely tightened up when putting it together.)
dancce
   / first repair #3
A lot of times when hooking up hyd lines you have to snug up and check for twist and or position. It's easy to forget to go back and tighten firmly. Your best bet is to double check all of them.
I have cussed at a leak for days/weeks only to find it just needed tightening! Also cussed and found it needed serious repair and any attempt to tighten made it worse!
If you want leak free hyd's never put fluid in them!
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
UNUSED FUTURE 15" EXCAVATOR GRAPPLE (A51248)
UNUSED FUTURE 15"...
2009 SolarTech Silent Messenger III Solar Message (A53117)
2009 SolarTech...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
