First regen 2860e
   / First regen 2860e #1
Skeletor
Massey Ferguson 1725mb
Had the first regen yesterday at 27.2 hours. The light was flashing so
I just decided to park it and let it do its thing. I raised the loader a bit so the exhaust wouldn’t blow in the loader arm for that long. Then I set the rpm to 22-2300 and just let it go. It probably took 20-25 mins I didn’t sit there and watch it. Curious to see if the next one will be about the same run time when it happens again. I let it run a bit at 1500 before I shut it down.
   / First regen 2860e #2
Why would you stop using it?
Just keep on doing what you did while it's regenerating.
   / First regen 2860e #3
Working through the Regen will very likely also reduce the Regen time. Different machine, but my regens average about 13.5 minutes, every 50 hours or so.
   / First regen 2860e
Just keep on doing what you did while it's regenerating. I was about done with it so I just let it do its thing .
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A49461)
2013 GMC Sierra...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2010 Case 660 Trencher (A50322)
2010 Case 660...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
