First post with a few questions
   / First post with a few questions #1
Mr Grasshopper
Queensland Australia
John Deere X595
Hello everybody this is my first post here. Be gentle with me :) .
I have never owned a ride on mower (or a diesel for that matter) before and have recently got myself a second hand JD X595 with 900 hrs on the clock.
Today while giving it a clean up and general inspection I removed the air box assembly to give it a clean and noticed that the rubber pipe that leads to the plenum chamber had heaps of black sooty deposits inside it :eek: kinda freaked me out . Just wanted to know is this normal for diesel engines and what is the best way to clean that gunk out.
I will also be changing all the fluids on it soon and was thinking of using Mobil 1 5w-50 in the engine would this be OK or what type of oil do you use in your machine ?
Any other tips you may have about these machines would be great . Thanks .
   / First post with a few questions #2
you don't know if the prior owner had stale fuel in there, so I'd give your new JD a big slug of diesel fuel cleaner.
As far as oil, synthetics are good, your machine is still relatively low hour, but you need to be careful with your oil; what does your manual state?
Many small diesels run on 15/40 but you are always safer, particularly with a machine new to you, to put in what JD recommends.
A lot of black soot could mean the engine was run with a constricted air filter for awhile. or maybe run at too slow a speed for too long a period.
:welcome:
   / First post with a few questions #3
Welcome aboard Mr Grasshopper - that's a fine mower you have..
Make sure it's diesel rated oil (CF-4, AH-4, C-4, CF, C-4 PLUS, CJ-4).
SJ, Sl, SM, SN oils are for gas engines.
http://www.upmpg.com/motor_oil_rate_gas.htm
I remember it as C for compression ignition, S for spark ignition.
Your manual will be more specific - if you don't have a manual, get one, as there's lots of information about your specific machine in it.
   / First post with a few questions #4
I have never ran 50 W oil in any engine even if it is multiviscosity. 10w-40 or 10W-30 is most recommended weights. I run Shell Rotella T6 10W-40 in my diesel equipment which is better than spec calls for, but I don't put a lot of hours on them and yearly oil changes are the normal so I figure the synthetic will do a bit better than Dino oil but who knows, it all should work fine as long as it meets the diesel oil rating of CF-4 or CJ-4
   / First post with a few questions #5
This can help until you get a paper one, or they are available on CD at your JD dealer. Or On line see below.
OMM151820_I4
James K0UA
   / First post with a few questions #6
:welcome: To TBN
Thanks for the warm welcome guys .... I will look into the diesel rated oils.
I'm still worried about all the deposits inside the intake. On closer inspection I have found that the air intake pipe has a small crack in the plastic where the air filter change indicator meets the main air intake pipe to the engine. So I cant work out if it has been sucking in dirt and causing the build up or if its carbon deposits.
I will take the plastic part to a plastic welder to get fixed up ASAP.
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
2008 FORD F-450 (A50854)
2008 FORD F-450...
2004 KENWORTH BUCKET TRUCK(INOPERABLE) (A50854)
2004 KENWORTH...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
