First Oil Change on 6000, Experiences.....
   / First Oil Change on 6000, Experiences..... #1
Y2KF250PSD
Central Oklahoma
Thought I would post about my fun with the 1st oil change.
I used the same enclosed oil drain pain that I use with my vehicles. It has a hole in the top that the oil drains into and a vent that you better make sure is open. I made the mistake once of forgetting to open the vent and the oil backed up and overflowed out of the pan all over the floor. Won't make that mistake again! /forums/images/graemlins/shocked.gif
So, my engine is warm, and everything is ready. I place my drain pan under the engine and confirm that I opened the vent hole. Unscrew the oil drain and removed it. This is when I learned that the drain hole is much larger that those on my other vehicles!! /forums/images/graemlins/tongue.gif
This results in the oil coming out fast! So fast in fact, the hole in the top of my drain pan could not keep up. So, I stood there and watched it overflow and run all the floor of my trailer that the tractor was sitting on. Like an idiot, I tried to stick my finger over the drain hole to slow the flow of oil coming out. All this resulted in was hot oil running down my arm and all over my coat sleeve. /forums/images/graemlins/crazy.gif
Make sure you use a bucket or other open container to drain the oil on these tractors guys!!
I figured that was gonna be my only mishap. Filter change was uneventful. Filled new filter with new oil before installing. I punched a hole in the bottom of the old filter to let it drain before removing it. You would be surprised how much silver glitter came out of that filter! Lots on the drain plug magnet too. It is definitely important not to postpone this 1st oil change past 50 hours.
Time refill the engine oil. I had read on here from another helpful member that it's a good idea to leave the dipstick out while pouring in oil so the engine is vented and won't back up the oil. Remembered to do that. Placed my funnel in the fill hole, (on top of that stupid splash plate) and proceeded to pour in the oil. I might add, the oil has been sitting in my cold garage and was quite thick. Guess what. Even with the dipstick out, the oil don't go in very fast. So, it backed up and overflowed out of the fill hole. Wonderful. Make note to self, pour very slowly.
Next item. It's time to start the tractor and run it a minute to circulate the oil before final topoff. I figure with that huge splashplate in the top, I can start it with the fill cap off. Nope. It will splash oil out whan you start it. Add another note to self. Put cap back on before starting tractor.
I'll know these things next time, hope this experience helps someone out. /forums/images/graemlins/grin.gif
   / First Oil Change on 6000, Experiences..... #2
Going to be changing the oil in my 4110 for the first time very soon. Thanks for the funny story and tips. Thought those type of things only happened to me.
   / First Oil Change on 6000, Experiences..... #3
Yo Dude!! Way to go. I will give you one more hint....If you put your oil filter on even hand tight (ie. 3/4 turn after it makes contact), you better back it off a tad as it will seal up to the point you can't get it off without turning the oil cooler just above the mating surface. Suggest you do this now. I can't get the filter off now as the cooler wants to come off with it!. PS there is a radiator line running in/out of this thing which has a rubber connector. Get the drift here.....
BobG in VA who over flowed the the pour in the first time, but learned his lesson on the 2nd change. PS. I noted that in the Service Manual (I have it too), it states that first oil change should be at 20 hrs. I changed mine at 21 and 53 hrs. I had a very small amount of fine "dust" on the drain plug magnet the first time and less the second. BobG out.
   / First Oil Change on 6000, Experiences..... #4
Thanks for the story & info, hope my oil & filter change will be a little less eventful. What brand & type oil did you use. New 6000 2wd. owner
CountryCousin,
I used Shell Rotella T 15w40.
This is what I always use in my truck and always have some on hand.
It's good oil, one of the best in my opinion.
Thanks for the tip Bob, I sent you a PM.
Wonder why the service manual differs from the owner manual on the hours?
I thought 50 hours seemed a bit long for break-in oil to stay in and questioned the service guy at the dealership about it. He said 50 hours was what they recommend. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / First Oil Change on 6000, Experiences..... #7
One last suggestion. Take your oil inside overnight (where it can warm up), so it will flow better the next day, when you do the oil change, especially in winter. That way, the oil will pour easier and not be so thick. This should solve most of the oil backing up in the funnel problem.
   / First Oil Change on 6000, Experiences..... #8
Not a bad suggestion, but its not the viscousness of the oil. The baffel just under the fill hole is the culprit. I changed mine the first time in hot weather (last summer) and it overflowed until I undid the dipstick and poured slowly. BobG in VA
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
International 806 2wd Tractor (A52128)
International 806...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
