first oil change on 3038
   / first oil change on 3038 #1
retiredmgn
Hi folks,
I went shopping today to pick up engine oil for 50 hour change. Dang. Changed my share of oil but this time I wanted to 'do by the book'.
Never payed attention to much more than viscosity but the JD manual lists several specifications from the manual as follows -
John Deere Plus-50 is recommended (thanks anyways but JD oil is pricey)
ACEA Specification E4/E5 may be used (couldn't find this spec on any oil)
Other oils may be used if the meet one or more of the following:
API Service Classification C1-4 (nope)
API Service Classification CH4 (nope again)
ACEA Specification E3 (scarcer than hens teeth)
To top it all off I came across oils that were labled "Desiel" (but without said specs) and others listed "for gasoline".
The chart in the manual shows I should use SAE 5W-30.
Sooooo, what do you guys use??
   / first oil change on 3038 #2
Due to the small amount of oil you'll need (4-5 quarts), I suggest you just ante up and get the JD oil.
After all, it's unlikely you'll be changing the oil more often then once a year...
You make a good point Roy. And I might end up doing just that. Thing is, what I learned to day shows I have a lot to learn about using the proper oil for a machine. I like to educate myself on these 'details' so I ain't just wingin' it.
   / first oil change on 3038 #4
on my 3520 I use 15-40 Shell Rotella T. That is the weight that they said to use in it, so i use it. That oil is used in everything from semies to these little tractors and everything in between. I used it in my Duromax pickups that I had, and it worked fine.
Your tractor sounds like it needs a thinner weight oil than mine did.
Let us know if you find an oil that meets all those requirements. Besides Deer.
   / first oil change on 3038 #6
I think if you compare apples to apples-you will find the JD oil is competitively priced. But OTOH, I would have now problem using Rotella either.
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
2007 Yamaha Rhino 660 (A55218)
2007 Yamaha Rhino...
JCB 270T T4 SKID STEER (A52705)
JCB 270T T4 SKID...
RIGID TOOLBOX (A52472)
