First looks
   / First looks #1
BWa
Brockton / West Bridgewater Ma.
2002 JD 990
Went to see a local dealer , asked about a 5320 , MFWD, PowerRev. Trans. ,tilt Wheel , Horiz. Rear Exhst. R1's (14.9-28 6PR , 9.5-24 6PR) tripl. rear SCV w/LVRS std. Draft Links , Iso. station ......... $35,748.00 plus 5% sales tax Here ouch , was told I could not order or buy , back hoe due to power beyond value not ready until later next year , will not take an order now or deal as package this is only first talk and only one of other dealers I will talk to , Can get std tractor (no platform ) with the P.B. value now and have 6 Week delivery ......what gets ???????
   / First looks #2
I noticed the lack of power beyond valve for the iso platform when you "build" your tractor on the deere site. Is the power beyond a gotta have with the backhoe? If the hoe had separate hydraulics wouldn't need it? The power beyond is expensive option isn't it ($1,000) ? What else would it be used for? Might see what the hoe costs with separate hydraualics. What hoe are you considering. I had talked with a woods dealer and he said the 9000 was all he would put on a 5000 series. The 1050 was too much hoe for it. I also spoke with the Bradco dealer and he didn't see a problem with using their 611 hoe (comparable to the 1050 woods) with a 5000 series but strongly suggested a sub-frame. The 611 hoe has the best specs in the class.
Did you have a front loader in the price?
IF not that sounds high. I haven't price any yet but thought that kinda price would get a 5420 or 5520.
   / First looks
Yes this is high , but have not talked final buy or dealer, of the fact this is cash ............have talked to two dealers as of this date ...as follows for only quote , will get dealer 2 on monday the 17th .......
base tractor $ 23152.00
MFWD 5378.00
Open Station Tilt 182.00
Steering
Powerreverser Trans. 2885.00
Power Beyond Valve 1000.00
(told it was required for backhoe )
Telescoping Draft Links 267.00
R1's 14.9-28 / 9.5-24 6PR
Base Total $32,864.00
Options
Hood Guard $126.00
Rear Triple SCV 1464.00
Mid-Mount SCV
FEL self leveling #541 5327.00
Power Tiller 3400.00
Iso. Open Plateform 990.00
w/o tilt/telescop. steering
Option attachment
#49 backhoe w/18' bucket 10460.00
Total $54,631.00
5% sales tax 2,731.00
Grand Total $57,362.00
No backhoe Grand Total $46,379.00
It's a start ......
   / First looks #4
That price sounds high, and Ill tell you why (kinda rhymes huh/w3tcompact/icons/smile.gif). I paid $35,000 for the following tractor earlier this year
5520
MFWD
Isoloted operators station
Tilt Steering Wheel
Power Reverser
Telescoping draft lnks
541 MSL loader
dual rear SCV's
18.4 X 30 rear tires
12.4 X 24 front tires
This seems quote similar to your tractor, except mine should be about $4000 more as it is a 5520, not a 5320 (my dealer told me it should be about $2000 per model within the 5000 series). I think that your dealer is trying to get rich off this one sale. Your quote includes the triple rear SCV package, while mine only has dual rear, but I think that this should only add about $500.
Here is the price list from JDLawns.com for the JD5320
2WD, Standard Station, Collar Shift, Bar Tires $19,700.00
Tilt Steering Wheel Add $151.00
Isolated Open Station Package Add $835.00
Cab Add $7,290.00
Cab With Air Suspension Seat Add $7,875.00
Limited Slip MFWD Add $4,390.00
SyncShuttleTransmission Add $605.00
SyncShuttleTransmission With Shiftable PTO Add $870.00
PowrReverser Transmission Add $2,575.00
Dual Selective Control Hydraulic Valve Add $850.00
Telescoping Draft Links Add $240.00
14.9-28 Bar Tires & Fronts (Recommended 2WD ) $120.00
16.9-24 Industrial Tires & Fronts (Recommended 2WD ) $290.00
21.5L-16.1 Turf & Fronts (Recommended 2WD) $340.00
14.9-28 Bar Tires & Fronts (Recommended 4WD ) $220.00
16.9-24 Industrial Tires & Fronts (Recommended 4WD ) $615.00
21.5L-16.1 Turf & Fronts (Recommended 4WD) $380.00
rf33
/w3tcompact/icons/wink.gif
   / First looks #5
Check out deere.com, Those are list prices. RF33 is in the ball park of what I thought you would buy one for.
Is the 49 hoe replacing the 10A? What are the specs on it?
RF33, any problems with your set up?
What buckets are avail for the FEL?
thanks
   / First looks #6
BWa, imho you should get the biggest r-1 tires available, consider Woods hoe w/hyd. pump and the largest and smallest bucket they will paint it JD green for you, go with step over station because I dont like where the fuel tank is otherwise and controls on fender are not brush friendly.
Tell him to drop sales tax because you are sweet corn farmer. Arent you?
And what is a power tiller?
Steve
Champagne Taste, Beer Budget
   / First looks #7
The only problem with my set up is that the tractor seat has been empty too much lately.
rf33
   / First looks #8
Happy and Sad to here that RF33!
RDLN, Which Woods hoe would you put with the 5000 series? I spoke with a Woods dealer and he said the 1050 was too much for a 5000 series, better go with the 9000 Woods. I then spoke to a Bradco dealer and he didn't see a problem with the 611 (their most powerful hoe and better specs than the woods 1050) on a 5000 series. What do you guys think?
   / First looks #9
I love my 7500 on my 970 except for the frame mount, I know it's the best for the tractor thats why I bought it, but the ground clearance reduction and extra overhang on the rear is rediculous.
My suggestion for the Woods BH is based on the assumption that JD's (made by Great Bend?) would be more $$$. As far as which model, well its a big purchase, if possible demo both on same machine. Make sure the 9000 boom will lift and position the 5XXX first and consider that w/3pt mount on tractor with shorter tires and 1050 BH with frame with the taller tires like rf33 has. Note: I don't believe Woods paints the 1050 in you favorite flavors.
Steve
   / First looks #10
Steve
Are you saying that my deere 47 bh is made by Woods?
Jerry
WOODS DS8.50 LOT NUMBER 247 (A53084)
WOODS DS8.50 LOT...
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
2013 FORD F550 SHUTTLE BUS (A52576)
2013 FORD F550...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
JOHN DEERE LOT NUMBER 121 (A53084)
JOHN DEERE LOT...
