PHPaul
Platinum Member
- Joined
- Feb 15, 2011
- Messages
- 760
- Location
- Downeast Maine
- Tractor
- Kubota B2650 with cab, Pasquali 986
Picked it up at the dealer yesterday after waiting nearly 4 weeks for them to get one in. They couldn't arrange delivery until mid-to-late next week, but I was all done waiting, thank you, so I drove up and picked it up.
Got some seat time today and discovered a few things:
1. My Woods 650 3PH backhoe is NOT going to fit without modification. It's got to be set back at least 6 inches and the upper mounting point is a shade too wide to fit in the bracket on the tractor. I'm going to meditate on that for a while and decide if I should modify it, or just sell it and rent a trackhoe when I need one.
2. The rear remotes I had added are a different size (larger) and not compatible with my existing hoses and cylinders for the box blade and snowblower. Just need to get the appropriate adapters.
3. The hydro whine is REALLY loud under load. Going to have to start wearing ear protectors.
4. Otherwise, the hydro is handier than a pocket on a shirt. Never really thought about how much time I spent shifting the trans and range levers on the JD. I was a bit concerned about how well a hydro would work under a heavy load, so I put the box blade on and set the rippers as low as they would go and tore the dickens out of my badly pot-holed driveway. It handled it fine, but I'll be some glad to get the hydraulic toplink operational.
5. The loaded rears make quite a difference. I tilled a neighbor's garden without needing 4WD, which I couldn't do with the JD. Speaking of tilling, the cruise control is nice, but it doesn't pop off when you hit the brakes. You need to set it back to zero to change direction or stop. Hafta remember that.
6. The cab makes hooking up implements harder for two reasons: Less clearance at the rear of the tractor, and having to go around the through the doors to tweak the 3PH position.
7. LOT of glass on that cab. Excellent visibility, but even with temps in the high 40's, when the sun comes out it gets warm in there. I actually ran the AC for a few minutes.
8. God Bless the man that invented power steering.
