First Harvest Accident--Age 76
   / First Harvest Accident--Age 76 #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
The picture, looking out the rear cab glass, shows the "no mans land" that one has to cross behind the cab to get to the rear view mirror on the right side of the tractor. The only "steps" are the two knuckles at the ends of the 3PH rockshaft and the only thing to hang on to is the magnetic radio antenna base on top of the cab. I've been holding on to this "security device" for the last 10 years doing dozens of mirror adjustments to provide visibility of the combine auger while unloading on the go into the grain cart knowing full well that the magnet would probably not hold if I needed it to. It didn't and the antenna ended up right next to me on the ground where I was flat on my back looking up at the sky and wondering if Grandpa should even try to get back up.
There were several "bumps in the road" on the journey from up to down as evidenced by leg and arm bruises in addition to severe back strain. Still can't figure out exactly what route was utilized thru the maze between here and there.
   / First Harvest Accident--Age 76 #2
We all do things we know we shouldn't but we still do. Thankfully you made it through the maze - there are a lot of very hard points that I will bet each left there own mark! Now you can rest though and let them heal.
   / First Harvest Accident--Age 76 #3
Ouch! Hopefully all that you received was bumps and bruises.
   / First Harvest Accident--Age 76 #4
The school of hards knocks is a brutal but effective teacher..
Glad you are up and atem .
   / First Harvest Accident--Age 76 #5
Sore and bruised has always been a great reminder to me that I could have really been "messed up" and to be careful.
Getting old... all your chit gets slow, slow to realize what's happening, slow to catch yourself and react and the worst part, slow to heal.
Careful out there old man ! (y)
   / First Harvest Accident--Age 76 #6
About a month ago I was needing to get a small box that I had stored on the 8” horizontal purlin in my metal building. It was above the sink cabinet. In the past I would get my 3 step stool to get up on the counter to reach the box. This time my 6’ ladder was right next to where I needed to climb up. I leaned the ladder against the counter and climbed up. BUT, when I stepped off the ladder to the right to get on the counter, the ladder kicked out. DUMB! I first fell against the right wall and ripped the towel holder off the wall. Then fell on the counter and bounced off. Ended up on the floor flat on my back.
I must have landed on my butt on the floor because I has a sore left cheek for about a week. No bruise.
On retrospect, I realized that if I had landed on my head, I might not be here anymore.
I know better but sometimes a shortcut seems easier.
I'm amazed at no broken bones falling off the tractor. My feet were about six feet above ground to start with but hitting the obstacles on the way down and breaking the fall may have been what saved me.
Here's the arm bruise about a week after. A hematoma about the size of a extra large lemon showed up immediately after the fall but was down in a few hours. Probably should use the pic as my avatar reminder. No?
   / First Harvest Accident--Age 76 #9
About as bad as trying to clean the back window on those cabs, climbing up on 3 pt arms and pto shafts and shields to get the window clean enough to see out especially when looking into the sun.
It would sure be handy if the manufacturer provided some safe places to step as well as some handholds for pete's sake. I have to wonder where all this falls in the product liability spectrum?
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
2008 IC Corporation PB205 Bus, VIN # 4DRBVAANX8A506494 (A51572)
2008 IC...
2016 Ram ProMaster 1500 Van, VIN # 3C6TRVAG2GE105143 (A51572)
2016 Ram ProMaster...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
