First Dislike
   / First Dislike #1
Hinomotoman
Western NC
LS R3039, Hinomoto E2604, Hinomoto N239, Case IH 1140, White Field Boss 31
I don't like how you empty the loader bucket and try to drag the pile backwards and it just flops around. So far, everything else is great.:cool2:
Eugene
   / First Dislike #2
That's normal for pretty much everything with a bucket on it. A little bump on the joystick in the uncurl direction is all it takes to reset it.
   / First Dislike #3
How are you back dragging and what is flopping around? Are the quick attach handles engaged into the bottom of the bucket? They must be or it would fall off. I have back dragged dirt and stone with mine without problems. Did you accidentally have the loader in float mode? In float mode the loader may rise up and go over the pile without doing much dragging. After you have most of the pile dragged then use float mode to smooth it out.
   / First Dislike
With the bucket in dump position, it just swings, it won't lock in position like all the other ones I've had.
Eugene
   / First Dislike #5
That sounds like a loader valve problem. Might have to let the dealer know about that.
   / First Dislike #7
If the boom well not float and the bucket is floating, just change the work ports around.
   / First Dislike #8
Yes it does. Add some RPM and stay on the curl and it will come around to the stop.
Bob
This sounds right....most have a spot that's sort of loose before they lock in place.
   / First Dislike
   / First Dislike
It does come around to the stop and then you can grab it by your hand and swing it.
Eugene
2016 KUBOTA RTV-X900 UTV (A51242)
2016 KUBOTA...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
2001 Ford Ranger XL (A50323)
2001 Ford Ranger...
TRAILER AXLE (A51244)
Dodge Charger (A50324)
2014 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
