I was once again on the backhoe tonight. With 4 hrs on the clock the engine suddenly went to idle. I throttled back up and again it returned to idle as I let off the lever. I pulled the cover and found the double nut (or bolt and nut) to be at least finger tight, so a grabbed a 1/2" wrench and loosened the lower nut (which is actually a bolt head)...then tightened the upper nut untill the throttle would hold it's position, then locked it down.
I think the vibes might have simply caused the friction fit between the nut and the painted bracket to wear through the paint and loose it's bite.
