Fireplace cleaning methods
   / Fireplace cleaning methods #1
slowrev
Elite Member
Goffs Corner, KY
IH 2444
I just removed a fireplace insert from a fireplace in my house. Going to put in some gas logs.
What is the best way to clean up the crud inside the fireplace. It is brick lined. What product or procedure works for you ?
Thanks in advance for your replies.
   / Fireplace cleaning methods #2
After a good vacuuming, I would use a muriatic acid solution. Start out weak, and prepare for plenty of mess, and a way to rinse with water and mop up the water. Good luck.
Check into a fireplace dealer and ask, or where you are getting the gas logs.
Sort of figured it would be a messy/stinky rubber gloves type of operation /forums/images/graemlins/smile.gif Thanks, Going to check for cleaners at Lowes today.
   / Fireplace cleaning methods #4
I've never tried it.. but I wonder what an oven cleaner product might do?
Oven cleaner might work well, thanks, I had not thought of that. It does make a good paint stripper.
   / Fireplace cleaning methods #6
not sure about the oven cleaner? I would try a SMALL part, up near the top in the top row of bricks... fire bricks are permiable so anything that sprays on them may soak in and cause a possable stink for a while... like someone said ask the gas log seller for sure... also those bricks can break pretty easy after being heated & coole a bunch of times! so be carefull...
MarkM /forums/images/graemlins/shocked.gif
I bought a squirt bottle of fireplace cleaner at Lowes. Works fairly well. A LOT of scrubbing with a brush is involved in the process /forums/images/graemlins/frown.gif
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2005 Big Tex 23ft T/A Flatbed Trailer (A52377)
2005 Big Tex 23ft...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
Powder River Squeeze Chute (A55218)
Powder River...
