Firebrick
   / Firebrick #1
RavensRoost
Phoenix AZ and offgrid weekend place south of Pres
John Deere 4500 and Mule 3010 (gas)
Nephews found a free wood heating stove for new hunting cabin, free is good has been our motto. Unfortunately, several of the firebricks are cracked and/or broken. The size it uses is 12" x 6" x 1" -- 4 across the back and 2 on each side -- held in place by steel racks.
I have not been able to find replacement firebricks in this size, most only carry the 9" x 4.5" x 1.25" "standard" size. Hesitant to burn it without replacing the firebricks, at least the broken ones, beginning to see why the stove was free.
Any suggestions on where to get this weird size firebrick?
   / Firebrick #2
May try asking over at hearth.com. It's like TBN for wood stoves (and equally addicting).
   / Firebrick #3
I have cut some to size for a shop stove once. Not that hard if you have the right blade.
I had a buddy use sheets of asbestos looking stuff about 1" thick he got from a fireplace store.
Personally I would cut it down to fit if you can, may take a few more pieces but not to bad.
   / Firebrick
If I could find a 1" slab, I would indeed cut my own, still looking. Phoenix is not a wood stove mecca. ;-)
   / Firebrick #5
You might consider getting some fireclay (and portland) and casting your own bricks...
   / Firebrick #6
Is it the hard or soft firebrick you are looking for? I think most larger concrete product (block/brick) suppliers would carry the hard type firebrick and may be able to tell you where you can get custom shapes if you are not willing to cut your own. The soft firebrick can be cut with a wood saw.
Another idea would be to contact an area foundry and ask them who does their masonry work or where they get their fire bricks.
Sounds like a pain, but may be worth a few phone calls.
Mark
   / Firebrick #7
Could you fix the existing bricks with stove cement? I think that's what it's called...a cement mix made for repairing stoves and such. If the cracks aren't too bad it might work. On the advice from a TBN member several years ago, I used it to make a temporary fix to an exhaust manifold. It lasted about as long as the manifold had before it cracked.
Chuck
   / Firebrick #8
I bought the brick and cut them in half length wise, to get 1.25". Used a masonry blade and a little water to keep the dust down, then cut to size. You may be able to find the hearth brick at Lowes or HD not sure..
Might try renovators online site too.
   / Firebrick #9
The soft firebrick can be cut with a wood saw.Mark
Firebrick is extremely abrasive, would like to see this in action. Saw would be useless afterward unless this is some sort of brick I am not familiar with.
   / Firebrick #10
Try and locate a boiler repair business. They have several types od firebrick. They also have castable mix to make your own. They usuall will ship to most anywhere. Just a thought.... :thumbsup:
2842 (A54756)
2842 (A54756)
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A56129)
2020 INTERNATIONAL...
