Fire preparedness and extinguishers
   / Fire preparedness and extinguishers #1
ponytug
Super Member
Bay Area, CA
Power Trac PT1445
Living in a rural area, we tend to take fire and fire risks very seriously. No fuel zones, gutter cleaning, keeping combustible materials away from buildings, etc.
We have a fire pump, numerous large dry powder extinguishers scattered around the ranch, and many garden hose type standpipes/hydrants with hoses and nozzles.
What we don't have are CO2 extinguishers for electrical fires; generators, etc. Anyone have tips on good sources for carbon dioxide extinguishers?
Thanks!
All the best,
Peter
   / Fire preparedness and extinguishers #2
Same situation here. I use ABC dry extinguishers. 1 in the garage, 1 in the shop, 2 on the tractor.
   / Fire preparedness and extinguishers #3
I picked up some old CO2 years ago at West Oakland Salvage… they were bought as scrap metal.
Went to ACME Fire Extinguisher and all passed Hydro and had them put new nozzles and fill
Don’t know if I would do all that for one but for 5 it was worth it at the time.
I was told CO2 is a dirty gas?
Any similar high pressure cylinder for Oxygen, Nitrogen and similar can be converted.
I have a source on E tanks but not the right size for extinguishers duty being tall and narrow.
Thanks! I will check with them. Or maybe not as they don't exist anymore. Is that right?
(And poke around closer to home at the salvage shops, though most seem to have given up retail sales.)
I have lots of dry powder extinguishers, but for generators, and tractors, I would like CO2 to minimize the damage to the equipment.
All the best,
Peter
   / Fire preparedness and extinguishers #5
ACME has been around many decades based in the Fruitvale district of Oakland.
They should be able to give you cost information or maybe have used to sell?
I know it’s a drive from where you are and probably every city has similar.
   / Fire preparedness and extinguishers #6
Amazon sells them. 5lb. for $200.
Maybe your local fire department could direct you to a local distributer for a better deal?
   / Fire preparedness and extinguishers #7
This vendor has pricing on 5, 10, 15 and 20lb CO2
   / Fire preparedness and extinguishers #8
I just bought several new extinguishers primarily for marine use, sports car, and shop.
Dry chemical, being a mess to clean up after use, was a no-go, at least for the boat and car. CO2 extinguishers are roughly 2x the physical size of Halon of the same size rating was deemed less than ideal in the tight quarters of the boat and sports car. Halon is deemed bad for the environment and the gas is no longer manufactured, although new Halon extinguishers with reclaimed Halon gas are available, but not inexpensive. Some other "Halon-like" alternatives are also available. They are also pricey.
So, what to do?! I bought Halon for the boat and car, and first defense in the garage. Existing dry chemical extinguishers are also in the garage.
Oh, buy quality, refillable extinguishers. That likely rules out buying from a big box store. When needed, the cost of a quality extinguisher will quickly become a distant memory.
I have used Halon, and "halon-lite" systems for work for many years. I still remember DuPont's original warehouse deluge ad. (So, yes, great marketing) I am tempted by the "noodle" type halon lite, e.g. the Blazecut T-300 types systems for some applications. It might work in the generator, but wouldn't work in the tractor.
All the best,
Peter
Thanks, I priced them out, and the price is low, but the shipping adds up. They are my plan B at the moment.
All the best,
Peter
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
Terms and Conditions (A47384)
Terms and...
2017 Ram 4500 Bucket Truck (A52128)
2017 Ram 4500...
BOBCAT QUICK ATTACH HYD SOD LAYER (A51244)
BOBCAT QUICK...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
