Fire in metal building
   / Fire in metal building #1
Ranger
Central & North Central Texas
Ford 2000, Gasoline - Ford 3000, Gasoline - Gehl 6635 Skid Steer
I have a 50x100 metal building in which a pick-up caught on fire and was destroyed. The fire was contained to the truck but the building and contents suffered heat and smoke damage. The building has the vinyl backed insulation which is typically used in metal buildings. Some of the smoke/soot got into the insulation. The smoke/soot is quite corrosive to the steel structure of the building (it has caused rust). Does anyone have knowledge/experience in just how corrosive this might be? Will the metal panels actually rust through in time or will it just become etched. Must I strip it all out and start over? What will happen if I do not strip out the old insulation?
   / Fire in metal building #2
Ranger, do you know the manufacture of the building. That would seem to be the best place to ask. I’ll be interested to see what the answer is to your questions.
By the way, welcome to the forum.
MarkV
   / Fire in metal building #3
I worked on dinner boats for a while and we had a liquid we would paint on the rust (very heavy rust on large valves), we would let it dry then paint it like we would any normal piece of metal. Perhaps this would work for you? I do not remember what the material is called but I have seen rust inverter(?) in NAPA and JCWhitney catalogs.
Good Luck, PTRich
PTRich - Thanks for the suggestion about the paint product.
It seems like Gempler's has a product such as you mentioned
MarkV - The building was not constructed by a company. Before I owned the property someone bought the components and some individual built the building. Thanks for the suggestion.
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
JOHN DEERE 850K LGP CRAWLER DOZER (A52705)
JOHN DEERE 850K...
(3) FLOOR JACKS (A53843)
(3) FLOOR JACKS...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
Honda Pioneer 700 NR (A53424)
Honda Pioneer 700...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
