Finishing Mower?
   / Finishing Mower? #1
HerTractor
Roanoke, VA
Kubota B6200 HST 4WD
I have been putting $400+ each yr into my riding lawn mower bc I treat it like a tractor. The 3 acres I mow with the lawnmower does not require a bush hog, it's just rural land. I usually do not let the grass get too tall, its mostly fescue and wild flowers. It does have rocks, sticks, tree debris, walnuts, etc. I am thinking about buying a rear mounted finishing mower to do most of the acreage mowing, and saving my lawn mower for the immediate area around the house. Question: the local farm equipment place has a 4 ft KingKutter I am thinking about buying. I've never had a finsihing mower before so I am asking you folks if I am thinking correctly that this is a viable option (my mower repair guy will miss me).
Thanks for your feedback.
   / Finishing Mower? #2
Personal opinion is yes. Been using a 59" Caroni finishing mower (about $1300 @ Agri-Supply) behind a 3038e to do the "lawn" areas & the in-laws' yard near our acreage for about 3 years now and it does a fine job of mowing. Only repairs to date have been replacing two wheels (tread wear/chipping from turnarounds on asphault) & one wheel fork (bent from carelessness). At Agri-Supply, that wasn't too pricey (totaled about $75...).
Nick
   / Finishing Mower? #3
Does it have to be new? What are you putting it behind (sorry if it's in your profile, I can't see it)? I have a woods rm90 finish mower that is kind of a hybrid finish/ rotary cutter. Very robust, with swinging blades and heavy deck. I have mowed 6' tall pastures with it. It doesn't leave a real manicured lawn, but much better than a rotary cutter and nearly riding mower quality. They made a smaller version rm59 if you need smaller. They can be found pretty cheap used.
   / Finishing Mower?
The one I am looking at is used, 4 ft is about as wide as I would want with my little tractor. I will be loking at the finishing mower this weekend, so hopefully can get a better idea of the type. It will be pulled by a Kubota B6200 4wd.
   / Finishing Mower?
That sounds much better than what I have been putting into my lawn mower!
Thanks.
   / Finishing Mower? #6
As long as you don't have a lot of obstacles to work around the finish mower works great. My Woods cuts as good as my riding mower.
   / Finishing Mower? #7
If you decide on a finish mower I would suggest a rear discharge model rather than a side discharge.
I use a rear discharge Sitrex 6 foot finish mower and the clipping come out the back in a nice wide thin layer.
It is really heavy duty (Made in Italy) and has given me trouble free service for the past 10 years.
   / Finishing Mower?
Thanks Antlers, I will be mowing around a few trees but nothing major. I do appreciate the feedback.
   / Finishing Mower?
I will certainly look at whether this is a rear discharge, DHD. I will probably do a drive by today to look at the mower. The guy said to come by even if he was closed.
   / Finishing Mower? #10
I think if you will have both, a rider and a finishing mower, you will be set. I use a 72" king kutter finishing mower to cut about 4 acres with a number of trees, and it cuts almost as nicely as my JD 355D. With the trees and other obstacles, you will leave uncut areas with a finish mower compared to your rider. I simply run my rider around and clean up what the finishing mower could not cut, so I find myself on the rider for about 15 minutes, compared to the 3 hours it used to take me to cut the lawn with the rider, so much less wear and tear on the rider if you are having repair issues.
And I agree with everyone, I purchased my finish mower used for $500, and it has worked great for 3 years without even having to change a belt.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
