Finish Mowing
   / Finish Mowing #1
CWP37
Hill Country, TX
John Deere 5103 w/ 512 LDR
My father in law just bought 30 acres down the road from me. He has an old Massey with a 7' shredder and I have a 5103 with an MX-6, so we have the pasture mowing covered. He's interested in a smaller tractor to pull a 5-6' finish mower or a MMM. He wants a tractor, rather than a ZTR or riding mower. He's leaning toward green so that his tractor will match my implements. My questions are:
1) What tractor/mower combo would be best for finish mowing 2-3 acres? Mostly open, with a few areas to weave in between trees. Also, one hill to mow straight up and down.
2) What kind of money are we looking at for the different models that fit?
3) What horsepower range? His current riding mower gets bogged down and won't cut very well, so he wants plenty of power for a good cut.
Thanks in advance.
   / Finish Mowing #2
Any of the subcompact deisels will work just fine. I have a 2305 (24/18HP) w/a 54" mulching deck and it will power through 8" high grass/clover, wet, and not skip a beat. It will cut just as fast as I can stand the ride. It also manuvers very well - much better than I had thought it would. Get a 62" deck, though - easier to get around tree's and over edges. That setup, w/ a FEL, will run ~$13K-14K. It will handle anything you can throw at it on 3 acres, cutting wise.
Implement wise, the 'limited' cat 1 hitch means it doesn't lift as high. It also has a far lower lift rating than your 5103. So if you're looking to share implements, look for something bigger than a 2305...
   / Finish Mowing
Thanks for the reply. How much bigger should he look at? Sounds like a 3120 would be a good fit, but maybe more than he's looking to spend.
What does anyone think about a 990 with a 6' finish mower?
   / Finish Mowing #4
CWP, the 990 should have more than enough muscle to handle a 6' finish mower. I looked at that model real close before I ran into a great deal on a low hour JD 970.
It's just slightly larger than the 970 and maybe 100 lbs heavier. But it's 5HP more at the PTO.
So, if you're not working in real thick or tall stuff -- likely go bigger on a finish type mower.
And (as you know...) it should handle your MX-6 real well, too!
AKfish
   / Finish Mowing #5
Nuther note --- the 990 is probably more machine than needed for 3-4 acres of finish mowing.
But if your Dad has ideas about the rest of the 30 acres, then having a 990 in the barn would be a good move. (And you might just like working that tractor a whole lot on your place, too!)
Best of luck in your decision.
AKfish
   / Finish Mowing #6
The 790 can handle a 72" finishing mower, so there's another one to look at. For just mowing, I'd think real seriously about a 2WD machine. For 2WD and power sterring, probably about $10K.
Also the 3203 too (but only if there's no chance it would be used as a stationary power unit)
How steep is that hill, BTW?
   / Finish Mowing
It's about a 20 degree grade up a house pad. My 5103 did fine, I'm assuming a 990 straight up and down would do fine.
What price should I be looking for on a 990 w/out a loader?
   / Finish Mowing #8
About $16600 if you go MFWD (MSRP per Deere's website). Make sure you get front weights as part of the deal.
I'm sure you can get 10% knocked off though.
   / Finish Mowing #9
I know I'm missing something here, but why not just buy a really good, big finish mower and use the tractor you already have? If it's big enough to handle a 7 foot shredder, you should have no problems with a bigger finish mower.
I have a 6 foot bush hog that I've been using for about four years. It works great, cuts through everything and I'm happy with it. It does take allot of effort to keep the height just right and I do scalp the ground from time to time, so for that reason, I've wanted a finish mower.
A month ago I bought a used 7 foot finish mower and can't believe the diference in the cut, how fast I can cut and how much nicer everything looks.
If you've been cutting with the shredder, then there's nothing in there that you can't cut with the finish mower. Once you start using one, there's no need to pull out the shredder any more. I know mine will be sitting for a very long time and I might even sell it. There's just no need for it where I can run the finish mower.
Eddie
   / Finish Mowing
That's a great idea, except his current tractor with the 7' shredder is about 20 years old and needs a total $6000 diesel overhaul. We figured a new tractor would make more sense.
I'm waiting for the Deer salesman to call me back with a quote, I'll post it for opinions and input when I get it.
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2013 RAM 4500 (A50323)
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A51692)
2012 Ford F-450...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2019 Toyota Corolla Sedan (A51694)
2019 Toyota...
