Finish Mowers
   / Finish Mowers #1
Anonymous Poster
Epic Contributor
What does everyone out there feel are the best quality(as far as sturdiness and cut quality) 3pt finish mowers?
   / Finish Mowers #2
If you do a quick search on finish mowers you will find all the information you could ask for on them. I think you'll find that Woods, Befco and Bush Hog brands in the top names. There are certainly others in the running such as Land Pride. These are all top quality mowers. Try the search and you'll see what everyone has experienced!
   / Finish Mowers #3
Ron, I don't know too much other then what I have. I have a 84" Landpride. I also have a Woods 80" "bush hog" While the Woods seems a little thicker as one would expect from a hog, the Landpride I have has the necessary strength where it needs it. Every place on my Woods that has dings or dents is where Landpride uses the thick steel. They did their homework. I really like the cut with the finish mower and the way it rides on 4 pneumatic tires and follows the ground. They are great unless the grass is really tough and tall. With much shorter blades, the speed of the blades is much higher and the degree to which they mulch the grass is much better. If I had it to do over, I would probably go for the 96" Landpride. Rat...
   / Finish Mowers #4
I use a Bush Hog Brand 72" (RDTH) mower on my TC45. Rear discharge. Use it to cut my 8 acre slawn & 5-6 acres next door about 5 times a year. No complaints. Easy height adjustment, four wheels to follow the ground. Also looked at LandPride which was a great looking unit as well.
Indiana Paul
   / Finish Mowers #5
I think you’re going to get a lot of good feedback on the top names brands, which would certainly include LandPride - I would not consider them just “in the running” but rather one of the top brands. I have over 100 hours on mine now and have never had any problems. When I did my research I found that the blade tip speed on the my FDR2572 was the highest of all the 6’ rear discharge mowers.
   / Finish Mowers #6
I don't think you can go wrong with any of the brands that have been mentioned in this thread. It probably will come down to which one you can get the best deal on.
   / Finish Mowers #7
I use a 6 foot rear discharge Woods. It is very solid and cuts great. Tires are solid with springs in the castor supports to absorb shocks. I bought mine before the talk of Woods having some difficulties with the company. Hope this dosen't make problems in getting parts.
   / Finish Mowers #8
<font color=blue>LandPride - I would not consider them just "in the running"</font color=blue>
I agree Danny. I didn't mean to word it that way. Land Pride makes top notch equipment. It's just that there are so many high quality brands I didn't know where to start!
   / Finish Mowers #9
Ron,
I got a great deal on a "private labeled" Caroni. It has been great for me, but this is the only one I have owned and it's 2 years old. So it's hard for me to compare.
   / Finish Mowers #10
Ron - Do you know how to start a discussion or what...
I have a 60" Farm King (manufactured by Buhler - check out: http://www.buhler.com/sitefiles/index1.htm).
Before I got this mower, my dealer loaned me a Rotomec... nice enough, but the FK weighs 552lbs and the Rotomec only weighs around 360lbs. The FK has a much larger gear box, larger wheels and is made of thicker metal.
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A53426)
2005 INTERNATIONAL...
UNUSED FUTURE PC711 - 71" HYD PLATE COMPACTOR (A51248)
UNUSED FUTURE...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
