Mosey
Veteran Member
- Joined
- Jan 4, 2002
- Messages
- 1,565
- Location
- Conifer, Colorado
- Tractor
- 2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
My Land Pride FDR2572 3pt pull behind finish mower has 10"x4" tires and I've had problems with it leaving ruts in soft ground. The mower will leave ruts even when the tractor, which is much heavier, doesn't leave ruts. It also scuffs the ground sometimes if I go from forward to reverse (or vice-versa) so that the casters have to pivot in one spot to change direction. Wider tires would be much better. I've noticed that other brands have about the same sized tires. I've also noticed that many of the zero turn type riding mowers have much wider tires, such as 13"x6.5". Does anybody agree that "wider is better" and that pull behind finish mowers need wider tires?
