Finish Mowers/Flail Mowers/???
   / Finish Mowers/Flail Mowers/??? #1
Anonymous Poster
Epic Contributor
I am new at this tractor business and although I have a vague idea what "finish mowers" are and what they do I am not sure of the details or if I could use one or not.
I have about 2 1/2 to 4 acres that has or will have lawn type grass, basicly flat with a small "slope", quite a few trees in addition to 2 buildings.
I have been using a 19.5/42" riding lawn mower, 3-4 hr job. I recently bought a Mahindra 5500 w/ a 6' cutter (bush hog) and it seems to do a pretty good job (about 1 hr). I plan to use the riding lawn mower to finish up around the trees, etc. If my wife gets her way (and they generally do) I'll probably have a couple of horse "turn outs" that will have to be kept neat. If the horses don't do it guess who'll get to?
What are the Pros/Cons. What type and size finish mower would suit my needs? What are common brands? What do costs run: new? used? Any pitfalls to be aware of?
Thanks for all the input I know you'll give. As my wife says "I need all the help I can get".
4570Forever
Houston
   / Finish Mowers/Flail Mowers/??? #2
I would consider the pastures and "finish" grass separately. Your bushhog will work fine for the pastures since you don't want them mowed too low anyway - the horses will take care of most of it anyway - you'll cut once in awhile just to even things out and hit the weed patches the horses won't eat. The rest can be done with a rear mount finish or a flail. Flail will cost more and is not necessary for a home. (A flail has a horizontal shaft that has maybe 50-75 small blades that dangle from a loop welded to the shaft. These are what actually cut the grass. Favored by municipalities that cut maedians etc cause if they hit a bottle, can etc they don't throw it like rotary mowers). For a rear mount finish mower new you're looking at $1000-1500 for a 60 inch. I have 10 acres, about 4 are pasture, 2 are finish grass and the rest is field. I use the bushhog for everything but an acre or so of finish grass right around the house. For that I have a 42 inch rider.
gerard - thanks for the reply it certainly helped. I've seen some mowers that appear to be the bush hog type but have an adjustable wheel on each "corner". Is this a type of finish mower?
You are exactly right about "experience".
Thanks again.
4570 Forever
2012 WABASH 53' DRY VAN TRAILER (A53843)
2012 WABASH 53'...
2008 Nissan Titan Pickup Truck (A51692)
2008 Nissan Titan...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Harrell 3605 (A50123)
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
