Mowing Finish mower vs rocks
   / Finish mower vs rocks #1
Boondox
Elite Member
Craftsbury Common, Vermont
Deere 4044R cab, Kubota KX-121-3S
Didn't get to the meadow in time to find/remove this year's crop of stones before the grass grew up to hide them. The poor LandPride FDR2572 mower found several of them and I couldn't believe the damage! The baffles are virtually gone, and one of the beefy blade spindles is cracked clear thru.
Photo of the underside is attached. Pete
Closeup of the spindle
This one is going to hurt the wallet. Pete
   / Finish mower vs rocks #4
Re: Closeup of the spindle
My dad always said---"never take a knife to gunfight" good luck!
   / Finish mower vs rocks #5
Pete,
My first thought when I read the topic (Finish mower vs. rocks) was "Rocks win" /forums/images/graemlins/frown.gif
The spindle looks bad. I hope you can find a way to repair it. If not, this could seriously cut into the budget for puppy treats and tennis balls. /forums/images/graemlins/shocked.gif
Good luck with this. It looks like a tough one.
   / Finish mower vs rocks #6
So that's what a trim mower looks like after it's been used as a rotary cutter... man... when I hit a rock.. I'm usually like "their goes my blade edge".. not.. "there goes the whole underside of my mower".. how long have you had it? Looking at your second picture.. it looks replaceable w/ those 4 bolts holding the spindle plate on.. you might be able to get just that part.. maybe a weldor can fab some new baffles.. or.. maybe it's just time for a new trim mower.. rotary cutter.. and rock rake! Those rocks are out there to get us.. cost me a rotary cutter(it was on it's last leg anyway).. sorry about the bad luck.. hope it's fixable!
   / Finish mower vs rocks #7
The mower almost always looses this battle. I spent about 5 days walking and digging out rocks and debry in my pasture and still the rocks "grew back" . I set my mower very high as well to minimize the risk of hitting a rock and damage it causes. I am considering a Land Pride RCR 2660 or 2672. I think you might want to do the same or at least go to the Tractor Supply Center and get a King Kutter 5 ft. rotary cutter for unsure areas. They are on sale this week for $549.
   / Finish mower vs rocks #8
how much pto hp does it take to run a 5' bush hog?
   / Finish mower vs rocks #9
</font><font color="blue" class="small">( how much pto hp does it take to run a 5' bush hog? )</font>
This topic has been discussed a lot, and a sorta general rule of thumb might be 5 hp per foot of width of the brush hog, or 25 PTO hp for the 5' brush hog. But it's by no means a firm requirement. If all you're cutting is grass and weeds with a light duty brush hog, you might get by with less hp. On the other hand, if you're wanting to mow down 2" saplings with a medium or heavy duty brush hog, you might need more.
   / Finish mower vs rocks #10
That is stupefying as well as depressing. All the baffles get torn off and a spindle shattered, yet the blades look relatively unscathed. Maybe I will rethink my idea of buying the Landpride RMM. Do you attribute any of this damage to weaknesses in the construction of the mower? I seem to recall some other problem you had with the mower and Carver.
2012 John Deere 410K (A47384)
2012 John Deere...
2000 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
2000 BOMAG...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
UNUSED FUTURE MINI EXCAVATOR RAKE (A51244)
UNUSED FUTURE MINI...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
