Tractor Sizing Finish mower size
   / Finish mower size #1
edmartin
Bronze Member
SC, USA
Yanmar YM2000
I need some feedback on how large of a finish mower I can use with my YM2000. Thanks
   / Finish mower size #2
I have a YM2000 myself. Have had it for five years now. I use a Caroni 6 foot (72 inch) finish mower. It does a great job. No power issues at all. I mow approximately 4 acres of yard each week. It is all flat. If I had a lot of hills or real rough ground, a 5 footer might work a bit better. The only thing I really wish for is that I think I would have liked rear discharge. Good luck.
   / Finish mower size #3
I would think side discharge would be better. If you mow in the proper direction you will re-mow the discharged grass for a finer mulch.
   / Finish mower size #4
Well Norm, I respectfully disagree. Although mine does a good job, some side discharge mowers have a tendency to windrow a bit if the grass is taller. Mowing in the proper direction would have your grass blowing out away from the grass. So you don't "mow" over the cut grass. I guess you could do that but kinda defeats the purpose. Just MHO.
   / Finish mower size #5
"Mowing in the proper direction would have your grass blowing out away from the grass. So you don't "mow" over the cut grass."
You lost me there; however, my mower discharges to the right, so if I mow in a clockwise direction, it discharges onto the unmown grass and gets mowed again.
   / Finish mower size #6
You are correct in what you say, but the consensus would be that is not the correct way to mow. I believe you are supposed to blow the grass away and not pile it up. But hey it's your grass, mow it however you want. I think it is harder to mow this way as in harder on the equipment and burns more fuel.
   / Finish mower size #7
You are right, side discharge is not better. That's just the way rotary cutters work, and most mowers seem to be side discharge; however, if you discharge into the unmown grass it WILL help to eliminate windrows. (That's my story and I'm sticking to it;) .)
   / Finish mower size #8
I have a YMG2000D and mow about 6.0 acres. I use a 5' KK with side discharge. I sometimes go a couple of weeks between mows. It came from my brother in law free. If I was to get a new mower I would go with a 5 or 6 ft rear discharge. The rear discharge uses less hp. thanks big dan
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53473)
2018 Link-Belt LBX...
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
