Finish mower gearbox
   / Finish mower gearbox #1
slckeys
ck4010sehc
I've got a gearbox from an 84" 3 point finish mower that decided to eat gears. It's a bobcat branded mower that's from around 2012. Parts NLA lucky me. I'm trying to find either gears to repair myself, or a whole be gearbox (prefer the cheaper option whichever that may be).
What I know... The input is 6 spline and the output is 1.25" diameter keyed with threads on the bottom for a castle nut. Gear ratio is 1:2.83. 34 teeth on the one gear, 12 on the other.
Any leads where I can look for just the gears? And I've been searching for hours for complete gearboxes.
Pictures can't be attached because the app will not let me for some reason...
   / Finish mower gearbox #2
Patco 014080 is on the gearbox itself. Forgot to include that. I haven't been able to find a thing on them...
Is there a gearbox brand that you can see? Did you try:
OR
Thank you for the links. I'll check them out when I've got more time.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2020 KUBOTA RTV...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
