Finish mower center roller?
/ Finish mower center roller? #1
Jeepnford
NE Missouri
Case DX35
I just bought a used Bush Hog 6ft finish mower. Looking at the manual a front center roller was optional, which mine doesn't have. Is the purpose of the roller to keep the center from digging into the ground if it slopes off each side of the mower? Worth adding?
/ Finish mower center roller? #2
Yes, called an anti scalp roller. No need if you are on flat ground.
/ Finish mower center roller? #3
I just bought a new RFM. I am mowing a former AG field and definitely wanted the middle roller -helps ride over old tractor ruts, etc. if I used the RFM on the section of lawn I mow with my ZTR, I wouldn't have bought it.
Will
Thanks for the responses. The place I'll be mowing is not completely flat so I'll likely add one.
/ Finish mower center roller? #5
I have a land pride 6' that was also optional and I do not have a flat spot on my property and mine mows fine without it. Yes.. I was thinking about putting one on. But so far I see no need.
iDrive TDS-2010H...
203201 (A60429)
203201 (A60429)
2016 Volkswagen Jetta Sedan (A59231)
2016 Volkswagen...
2019 Toro Workman GTX Electric Utility Cart (A59228)
2019 Toro Workman...
2005 International 4300 S/A Dump Truck with Scissor Lift (A59230)
2005 International...
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
