Finish mower caster wheels
   / Finish mower caster wheels #1
Mosey
Veteran Member
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
Has anyone had their finish mower caster wheels apart? I have a LandPride FDR2572. The manual, which calls the caster wheels "gauge wheels", has a diagram that shows how the wheel is connected to the yoke. Apparently, there are no roller bearings, just a bolt and a "spacer tube". Is that typical? One of the wheels has a fair amount of slop in it now, I can wiggle the top of the wheel left to right about 1/4”. I figured it would be a good winter project to take them all apart, clean, and inspect them. I don't want to wait until the wheel hub starts wearing before I replace the spacer tube. I've only used the mower for 2 summers, so I'm surprised it shows any wear at all already. I've always greased them as often as the book says, actually even more often, and I always keep it dry.
   / Finish mower caster wheels #2
Danny, unfortunately, I have the same situation with my Bush Hog finish mower. The wheel hubs show no wear, but the bolts that serve as axles are wearing, and the holes in the yokes are wallowing out (on the rear wheels; front ones are OK). Of course, I know that mine gets some pretty rough use, so I haven't felt like I had a complaint. I'm just going to have to replace those two bolts and do a little welding, grinding, and drilling to make the holes in the yoke the right size again.
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
2014 Morooka MST1500 Crawler Carrier (A52384)
2014 Morooka...
2006 Kubota L3130 (A50123)
2006 Kubota L3130...
2010 VANGUARD 53x102 DRY VAN (A53426)
2010 VANGUARD...
Year: 2019 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 177,369 Plate: Body Type: Cutaway (A51692)
Year: 2019 Make...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
