Fine threaded bolts vs Coarse threaded bolts ?
   / Fine threaded bolts vs Coarse threaded bolts ? #1
Mrwurm
Veteran Member
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
My last project here got me thinking about fine threads vs coarse threads. Most things that I work on have coarse threads. But, once in a while I work on something like my new New Holland front blade and find that every fastener on it is 1/2-20. This is the fine thread version of the typical 1/2-13 coarse fastener. To make things even more complicated, metric fastners come in three pitches. For example a 14 mm bolt may come in 1.5 threads per mm, 1.75 threads per mm, and 2.0 threads per mm.
So, what gives here ? What are the benefits to use either fine or coarse threads for the same given diameter bolt ?
   / Fine threaded bolts vs Coarse threaded bolts ? #2
Fine threaded fasteners have higher tensile strength than coarse thread fasteners. They also take more work (i.e. - revolutions of the fastening tool) than coarse thread.
More info:
BoltScience.com
Engineering Fundamentals
   / Fine threaded bolts vs Coarse threaded bolts ? #3
Hi
I think 1/4-20 is the standard and 1/4-28 would be the fine thread.
Charlie.
   / Fine threaded bolts vs Coarse threaded bolts ? #4
Back to Tapping Handbook Contents
Coarse vs. Fine Threads
Coarse Threads
For most applications, course threads offer these advantages:
* Easier and faster assembly, providing a better start with less chance of cross threading.
* Nicks and burrs from handling are less liable to affect assembly.
* They are less likely to seize in temperature applications and in joints where corrosion will form.
* Less prone to strip when threaded into lower strength metals.
* More easily tapped in brittle materials and or materials that crumble easily.
Fine Threads
Fine threads may make for a superior fastener for applications with specific strength or other requirements.
* They are about 10% stronger that coarse threads due to their greater cross-section area.
* In very hard materials, fine threads are easier to tap.
* They can be adjusted more precisely because of their smaller helix angle.
* Where length of engagement is limited, they provide greater strength.
* Thinner wall thickness can be used because of their smaller thread cross section."
Well ...that answers one of my oldest questions!!!
I'm glad you asked...I will sleep well tonight!! /forums/images/graemlins/grin.gif
   / Fine threaded bolts vs Coarse threaded bolts ? #5
Fine thread bolts have greater resistance to loosening than coarse. This is due to more contact area for the threads and less angle. That's why fine treads are used most of the time on engines and vehicles.
ksmmoto
Thanks to all. Great info ! /forums/images/graemlins/smile.gif
   / Fine threaded bolts vs Coarse threaded bolts ? #7
Fine threads are a great vocabulary enhancer when working in awkward areas.
Harry K
2014 PETERBILT 367 (A45046)
2014 PETERBILT 367...
Elephant Plate Compator 17-23T fits 320-325 CAT (A42203)
Elephant Plate...
ATV (A44572)
ATV (A44572)
1990 Ford Ranger 4x4 Pickup Truck, VIN # 1FTCR11TXLUC19238 (A44391)
1990 Ford Ranger...
Takeuchi TL240 (A42021)
Takeuchi TL240...
PT 1000 Gal Supply Tank (A44501)
PT 1000 Gal Supply...
