FINDING UNRESTORED YANMAR
   / FINDING UNRESTORED YANMAR #1
RobertMays
I want another Yanmar, around a 1610D in size and would like to know where to get one that hasn't been reconditioned. I would like to buy one that has been imported only. I am in TN but anywhere in the south would be fine.
   / FINDING UNRESTORED YANMAR #2
WELCOME Robert,
You are convieniently close to Frederick's in AL. I don't think you will find another dealer that is closer or better.
Mark
   / FINDING UNRESTORED YANMAR #3
The problem lies in the fact that it is exceedingly rare to find a unit that has nothing wrong with it...I'm sure there must be some in the thousands and thousands, but I have never seen one that didn't at least have a seal leaking. It isn't the reconditioning itself that poses a problem....and we prefer to call what we do "processing", as we put each unit through a process, but certainly do not replace the same items on each unit as the vn reconners seem to claim...it is how it is done. We won't sell a raw unit right out of the container. For starters, we HAVE to assemble the unit, and right there we have probably incurred some liability. For our sake as well as the customers', we want the unit to go through our process/checklist before we sell it. I think you will find the same true at Fredricks and most other responsible dealers, but you can certainly call and ask.
   / FINDING UNRESTORED YANMAR #6
Tullahoma processes their tractors too.....they just don't (as far as I know) use the same level processing as we do.
A totally raw, straight from Japan unit is going to be in many pieces.
   / FINDING UNRESTORED YANMAR #7
BruceR all the people that sale yanmar's don't get them from Japan. A lot of them get there tractor's from Fredrick's . there is not a thing wrong with Fredrick's , but if you get a tractor that came from a dealer that got it from Fredrick's it will have Fredrick's stickers on it .and if it is a bad tractor and the dealer don't want to make it good Fredrick's want them you got a problem.
   / FINDING UNRESTORED YANMAR #8
Careful what you wish for.
For every tractor that is no longer in service, there is a reason why it was retired. (Although Japanese tax/rapid depreciation law is one non-mechanical reason). An importer-dealer with lots of experience will have better intuition what could be wrong with a retired tractor, and what to do to put it back in service.
My Yanmar was originally sold new here in the US, and apparently was neglected worse than would be normal for a Yanmar in Japan. I'm a pretty good troubleshooter and had it running like new in a month but it needed a lot of stuff:
  • The dash warning light cluster was hanging by my knee.
  • Entire fuel filter assembly had been discarded, replaced by an automotive inline filter.
  • The seat had only the bare metal pan remaining.
  • Fuel leaks at the top of the injectors. I misdiagnosed that, and bought the expensive fuel fitting wrench before I figured out it was just the little fuel-return lines rotted out.
  • Everything squeaked like a mad symphony. I found loose lug nuts, loose loader-to-chassis bolts, loose bolts everywhere on the loader.
  • Rancid unburnable fuel in the tank. I had to dope it with Power Service before it would burn. I found the previous short term owner had ruined and replaced the starter due to this bad fuel.
  • Ugly stress cracks welded over, in both front wheels. A reputable dealer wouldn't sell a rig without replacing such damaged wheels.
  • Headlights bashed in.
  • Chassis-to-hood electrical connector smashed so no headlights.
  • Rubber 'shock absorbers' under seat smashed flat.
  • Rubber handle cover missing from 3-point lift lever.
This stuff wasn't expensive to fix but it took time. The first time I found a similar tractor to salvage parts off of, the dash light assembly and small rubber parts were cheap but they wanted $60 for the fuel filter assembly. I went back later and it was $10. But that one had been fitted with the wrong bowl so it wouldn't take Yanmar elements, so I had to buy a fuel bowl along with the correct element. Likewise, I found the headlight assemblies on ebay after several months for under $20 but good luck finding a similar deal.
The thing ran like a clock as soon as I put clean fuel in it, but it was clearly a gamble before that point.
I had it in service in a few days and pretty much 'renovated' in a month. (function, not appearance!) After four trouble-free years I feel I won the gamble. But I still haven't replaced those ugly welded-up wheels, or done anything about the appearance.
Are you SURE this is what you want? :)
A dealer would have taken care of all those issues within the retail price. And for most people, his price would be justified.
   / FINDING UNRESTORED YANMAR #9
That's true Wayne. Mine came in pieces, but all the pieces, including wheels and seat, were numbered to the specific tractor. And fluids and a new battery were added before I got it so I guess it, too, was "processed" I don't think RobertMays wants a pile of parts, but just maybe an honest Yanmar that hasn't been "processed" to the point of having a freshly painted oil filter.
Not looking to step on your toes, By all accounts you are a great dealer and a valuable resource to TBN.
Bruce
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
Electric Concrete Mixer (A51573)
Electric Concrete...
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
