Finding Rocks in Tall Grass
   / Finding Rocks in Tall Grass #1
JimHam
Bronze Member
Duffield, VA
Kubota M8200DTC
I own 55 acres of reclaimed strip mine land in So. IL and it has lots of rocks laying on the surface. I put it in the Conservation Stewardship program to keep my taxes down and in my 5 year plan I said we were going to maintain trails and firebreaks. So I wanted to start mowing firebreaks but the rocks have to be found which is not easy in the thick vegetation. I intend to burn it off section by section once I retire and get over there but in the meantime I want to start mowing the firebreaks. To find the rocks I decided to try and backdrag the bucket on my Kubota and see if it would pull the rocks up. Well, it doesn't pull the rocks up, unless they are really big, but you can quickly tell when you hit a rock even a small one. So, by putting the bucket down on "float" and backing through the grass I can find the rocks I would hit with the mower. Then I get to climb down from the cab and find them and throw them in the bucket. Now I am just trying to convince my wife to walk behind the bucket and I will just stop and she can throw the rocks in the bucket once I find them with the tractor. :thumbsup: Anyway, this dragging the bucket seems to be working so I thought I would share if anybody else has this situation.
   / Finding Rocks in Tall Grass #2
Best technique is to hire your neighbor to mow it the first time. :D
   / Finding Rocks in Tall Grass #4
Instead of using the cutting edge to back drag use the heel of the bucket. It won't ride I've as many and then when you get several pick up bucket backup and scoop. Or get a rock bucket like this. http://attachmentspecialists.com/rock-buckets/ a grapple will add usefulness.
   / Finding Rocks in Tall Grass #5
Your wife might be more interested if you taught her to drive the tractor and YOU walked. :)
How large are the rocks? Can you raise the cutter? A power rake is good for loosening the top layer of dirt and rock then it's just a matter of raking them into windrows. If the whole property is like that, you might consider investing in a rock picker. Or build one. They'll pick up the rocks as you drive and put them in a large bin that can be dumped.
And if you have rocks now, you'll have them forever so you'll need to equip and plan for it. Those rascals will dig their way to the surface on a constant basis. :)
   / Finding Rocks in Tall Grass #6
How about driving the firebreak path with a rear blade down, with the blade reversed? When it jumps, there is a rock.
Bruce
   / Finding Rocks in Tall Grass #7
Women never appreciate a truly well thought out plan :confused3:
I have no trouble finding rocks in tall grass, finding them before hitting them with the brush hog is the problem ;)
   / Finding Rocks in Tall Grass #8
What you really need is a teenager who wants to borrow your car. He will follow you anywhere! :thumbsup:
   / Finding Rocks in Tall Grass #9
I run my mower high, my loader down low, and watch as best I can. Still hit some rocks, and stumps, but that's just the way it is on rough ground.
I was using the heel of the bucket but I had it level not with the blade tilted up. I will try it tilted up and see if it will drag them. I don't have a back blade so that is out. I've been looking at the rock buckets but I've also seen rock forks that attach to the front of the bucket which would be cheaper and look pretty quick to install and remove. I have the older style bucket with pins not the quick attach. Forks would work well on bare ground but with the tall grasses I have a rock bucket would be loaded up with grass in about 10ft of travel. The rocks run anywhere from the size of a baseball to 2 ft. in Dia. Some are buried boulders that I cannot move even with the bucket. We'll be marking those and mowing around them. When the county put in the water lines last summer they used a track hoe and a dozer. Some of the boulders they dug up were 5 to 6 feet long and 3 ft dia. Burning off sections is part of my management plan so after I burn we can see the rocks and pick them up.
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
UNUSED JCT SKID STEER QUICK ATTACH SNOW PUSHER (A51244)
UNUSED JCT SKID...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
New Idea 324 2 Row Corn Picker (A50514)
New Idea 324 2 Row...
2014 CATERPILLAR 740B OFF ROAD DUMP (A51242)
2014 CATERPILLAR...
