Finding a buried water line
   / Finding a buried water line #1
quicksandfarmer
Veteran Member
Coastal Rhode Island
Jinma 354, purchased 2007
I used a new-to-me technique to find a buried water line today and thought I'd share it.
In the basement of my house there is a 3/4" black poly water line that exits through the foundation. It's connected to the house water. A previous owner put it in and I don't know where it goes. I've tried opening the valve to see if water shoots out but nothing doing, I think it must be capped.
I had some time today so I thought I would try to figure out where it goes. I shut off the valve and disconnected it in the basement. Then I took a long electricians fish tape and fed as much of it as I could into the pipe, I later measured that it took 58'. I have a wire locator that I got on Amazon for about $50, it's not very precise but it's been very handy. It's this one:
The way it works is there's a transmitter and a receiver, you clip one wire of the transmitter onto the wire you're trying to trace, the other onto ground, and then you walk around with the receiver, the closer you are to the wire the louder it beeps. So I clipped the transmitter onto the fish tape and went out into the yard with the receiver.
Walking around, I could trace the pipe where it came out of the house. I followed it and it turned and went by a small shed. I found a spot where the signal seemed to stop. I walked around a few times to be sure, and then started digging.
The pipe was directly below where I dug!
So it worked. The hitch is I didn't find the end, just the middle of the pipe. I followed it for a few feet until it got to be dinner time. I measured the distance from the house and I might be 2' short. I don't know if the end of the pipe is a little bit further along and I just need to dig it out, or the pipe could be filled with dirt or some other obstruction. I'm trying to decide how much further to dig before cutting the pipe and putting in a hydrant.
Anyway, I thought I'd share the technique because I feel pretty proud of myself.
   / Finding a buried water line #3
Nice. Thanks for sharing.. I have a wire to the pole barn I need to trace out (y)
   / Finding a buried water line #4
I can find wires or pipes with a pair of dowsing rods.
All it takes is 2 pieces of coat hanger wire.
   / Finding a buried water line #5
I’ve got a method, I can walk for three days into Denali National park away from the nearest road with a trenching shovel. As soon as that shovel touches dirt it will break a water pipe.
I offer my services to anyone, guarantee my work as well!
   / Finding a buried water line #6
sea2summit - you must be craving for "lost". Three days walk into Denali NP would DEFINITELY put you in the middle of "nowhere" Alaska.
The City of Anchorage had electronic "tools" used to find water lines. I think it had something to do with finding a void in the ground.
   / Finding a buried water line #7
Would you happen to know the range of that tool?
I'm sadly assuming it probably won't work you here where our lines are 12' down.....
   / Finding a buried water line #8
Yes I do that too. But I don't think everybody can do that. Finds dead people too. Go to a cemetery and try it. Points to the foot of a man and the head of a woman. It's really odd though because you find what you search for. I mean if you are looking for a water pipe the wires won't cross on an electric line, or vice versa.
Twelve feet is probably too much. I have found wires buried 4'. Since it's just an audible signal it's kind of like asking what's the range of AM radio, the limit is what you can hear.
It has adjustments on the transmitter power and receiver sensitivity because when you're close it can be too sensitive. This pipe was buried about 24" and I found with both on about half I got the best definition.
   / Finding a buried water line #10
I had a bit of a laugh to myself when I had the "call before you dig" guy out to locate a phone line before we trenched for a water pipe. After about 10 minutes struggling with the locator (apparently a weak signal from old phone lines) he took one of the marking flags bent at a right angle and found the line in about 30 seconds. Then went over the path he just walked with the locator and sure enough there it was....
Amazing a bent flag worked better than that few thousand dollar unit....
2007 IC PB10500 School Bus (A42742)
2007 IC PB10500...
(1) Small Blast Mat (A42021)
(1) Small Blast...
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A43004)
2019 INTERNATIONAL...
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A42742)
2025 Kivel 48in...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A43003)
2017 PETERBILT 579...
2018 JLG 1932R 19ft Electric Scissor Lift (A42742)
2018 JLG 1932R...
