Finally.... TN70DA
   / Finally.... TN70DA #1
Rowski
Veteran Member
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
Finally after a long wait its here! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif The wait was more than worth it. /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
I've only put a few hours on it but its just amazing. The loader is very strong, stronger than I thought it would be. I just played on a pile off old weed infested topsoil. The tractor feels very stable on slopes more so than the 2120. The cab and controls are nice too. I did do a little mowing in a wet area and was impressed with the floatation of the tires. I haven't put the 759C backhoe on it yet, I need to convert it over to a 3pt mount.
The hydraulic shuttle is awesome. If it holds up to long term use it will be even better. This system is so easy to change direction. In my opinion its easier and less fatiguing than a HST. For loader work I still need a bit more practice as I'm still looking to clutch. Also the loader is so strong you can burry your bucket in to a pile and it will break out with no problems.
I'm very very pleased. I would like to thank everyone for the help in my choice, especially the TN owners.
On to the punch list....
The A/C doesn't seem to cool. At idle it will cool the cab but start working and it gets weaker,if I turn off the a/c switch off the air seems to get a little warmer. I'll have to put my a/c gauges on and see what is happening. I think it just may be low on charge.
Yesterday when I was mowing I was backing up a steep slope it seemed like the shuttle was going into neutral for a split second. It didn't do it all the time and didn't seem to have enough a pattern. It didn't do it going forward. One thing I did notice is that at the dealers the 4wd light was on when driving up the trailer. When I got home and took it off the trailer I turned the 4wd off. When I went to turn it on again it would go into 4wd but the indicator light didn't light?? So there is a possibility that the 4wd was kicking out while backing?? I'll have to try it some more and see it I can isolate it some more.
Attached is a picture. I took more but this is the only one that made it to my home computer /forums/images/graemlins/frown.gif.
   / Finally.... TN70DA #2
Sweet tractor! /forums/images/graemlins/grin.gif
   / Finally.... TN70DA #3
I don't know much about your tractor or the shuttle shift but is it possible the linkage could need adjusted. The ony reason I say thisis because on a zero turn mower after a few hours you have to adjust the control levers and hydro transmissions due to air in teh lines and wear in. I know ther's a big difference between a ztr and your ig but I was just throwing an idea out there. Nice looking tractor.
   / Finally.... TN70DA #4
Nice looking machine.
You are waaaaaayyyy more patient than I am. How many months did you wait?
Enjoy.
   / Finally.... TN70DA #5
Congratulations on your new machine! /forums/images/graemlins/cool.gif It looks awesome!
I remember you were talking about a bigger tractor when we were visiting at Boondox's party.
Hope you get the A/C problem corrected. Can you tell if you're having a similar problem with the heat? Maybe the heat gets cooler. Is the control knob put on backwards?? Just kidding. Wouldn't it be nice if it were that simple? /forums/images/graemlins/smirk.gif
   / Finally.... TN70DA #6
Congrats on the new purchase. I bought my TN75A 4wd in August. 62 hours on it now. What a great machine!
Enjoy!
   / Finally.... TN70DA #7
Congratulations! I know it's been quite a while in the making. Enjoy! /forums/images/graemlins/cool.gif
   / Finally.... TN70DA #8
Nice pic. Now how about a smaller blue one on the right side? You'd have the complete set. /forums/images/graemlins/grin.gif Heard you and your Dad took it for a spin around the mountain. /forums/images/graemlins/grin.gif
Take care
   / Finally.... TN70DA #9
Derek
Congrats on finally geting it. The AC should freeze you out. The tractor automatically shifts into 4WD when you brake so you should see the 4WD drive light come on then. The transmission is very programmable so have your dealer hook it up and check it's settings. When they split mine to fix the tiny oil leak they reprogrammed it and totally changed its shifting characteristics. I had them reprogram it to my liking as far as delays, etc went. Enjoy. BTW, I can't break out my 84" hd bucket from a heavy pile and keep the rear end on the ground with loaded tires and a 8' box blade. I need about 1000 to 1200 # more weight I think.
Andy
</font><font color="blue" class="small">( You are waaaaaayyyy more patient than I am. How many months did you wait?
)</font>
Since early May '04.
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
