Finally I have started to put siding on my Lumber Kiln
   / Finally I have started to put siding on my Lumber Kiln #1
123maxbars
Kubota B3200
   / Finally I have started to put siding on my Lumber Kiln #2
I'd disagree board and batten is "the best" siding method, although it is a common method of siding.
Unless you get down and pump the gap at the bottom between the boards, over which the batten lays, full of caulk, you're creating a great hiding place for bugs to crawl up that gap between the boards...over wintering all kinds of them, and giving dirt daubers the best place in the world to build mud nests.
I prefer a taper cut, horizontal lap siding.....much tighter seal on the boards against bugs and air. A band mill is THE saw for cutting tapered lap siding. Simply cut the log down to a cant however wide you want the siding ( I use 8" with 6" exposed on the siding), and 'cock/uncock' the cant with couple 3/4" plywood shims with each pass of the saw.
enhance
I use it on everything from wood sheds to chicken coops to my shop.
enhance
enhance
enhance
JLG 1932R 19FT Electric Scissor Lift (A50322)
JLG 1932R 19FT...
Swict 78" Bucket (A50121)
Swict 78" Bucket...
2017 Nissan Titan Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
2016 Ford Explorer...
