Finally I have my tractor - now what?
   / Finally I have my tractor - now what? #1
russ207
Peachtree City, GA
Ford 640
As a 14 year old teenager in Kansas, I helped my dad overhaul tractors at Buck Astle's Ford dealership in Newton, KS. I remember the new model 600 setting in the showroom floor. Now, 58 years later, I finally procured a model 640. It does not look like that new one on the showroom floor. The tractor runs fine but it has several issues that will require fixing. I was pretty good at tearing down the old "n" model tractors back then, however many, many moons have set since then so I am going to need lots of help.
My issues are:
1. the previous owner had a clutch put in it. The lift worked fine before the installation but does not work now. I checked to make sure the pump (piston) was primed and it appears it is.
2. there is a knock or pop coming from the transmission in 2nd gear, no noises from 1st, 3rd, 4th or reverse. Maybe a broken tooth?
3. the steering works fine in a right turn but is very, very stiff turning to the left - the tractor has no power steering assist.
I have the manual and will follow it as I address the above issues. I would very much appreciate any thoughts you fellows might have that might help hasten my efforts to return my 640 to a proud iron horse.
Thanks, Russ Crawford
   / Finally I have my tractor - now what? #2
Welcome Russ, You need to post this in the Ford Forum so the Guru's over there can see it. They don't get out much.
Thanks Murph - I shall endeavour to persevere and look for the Ford tribe
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
New/Unused 7ft Stainless Steel Work Bench with 20 Drawers (A51573)
New/Unused 7ft...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
40ft High Cube Shipping Container (A51573)
40ft High Cube...
