crazylare1
- Joined
- Nov 21, 2005
- Messages
- 158
- Location
- Stanwood, MI
- Tractor
- JD 3320, JD GT235, JD 116, JD 57, an several other makes of lawntractors somewhere around 8 of them
Well I finally got my 3320 back from the dealer with all of my attachments, accessories, and backhoe! It was a long wait but will be worth it, sides that I got to put almost 40hrs on the tractor and get all of the bugs worked out, ie. the tire on the right side was hitting the steering cylinder fitting when turned all the way to the right, turned out to be that the center of the rim was welded to far out making the tire set in closer, a new rim fixed it, and the parking brake needed to be adjusted, other than that no problems. I tried out the hoe for a few minutes out in the swamp but the cold weather caused me to give up on playing with the hoe. I took it off the next day to put the back blade on because of the threat of a snow storm (didn't hit us /forums/images/graemlins/frown.gif ) but there is always spring time just around the corner /forums/images/graemlins/smile.gif. The hydrolics on the hoe seem a little whimpy but an adjustment on the pressure relief should take care of that. Take care all!
Larry
p.s. thanks go out to bloomington mike for editing my pic's so that I can post them on tbn, without his help I wouldn't be posting pic's. Thanks Mike!
Larry
