Finally found an accurate easy method to sharpen my saw
   / Finally found an accurate easy method to sharpen my saw #1
123maxbars
Kubota B3200
After years of mixed results I was introduced to the Stihl 2 and 1 Chainsaw sharpener. After the first use my dull chain now cuts with factory sharp accuracy. Made a short video showing the tool. Hope this helps some of you that struggle with sharpening your saws.
WRANGLERSTAR SHARPENING METHOD - YouTube
   / Finally found an accurate easy method to sharpen my saw #2
Thanks for posting. The 2-in-1 looks like a winner.
   / Finally found an accurate easy method to sharpen my saw #3
Pferd sells the same thing (I think they made the Stihl one).. I got 2 off amazon for about $23 each (i have a 3/8 on a stihl 031 and a MS170 ).. seems easy to use and efficient, even for beginners..
Check their website - they recommend different sizes files than the files when you hand file..
example - they recommend the 13/64th file to sharpen 3/8 chain..
PFERD Chain Saw Files & Accessories - CHAIN SHARP® CS-X - CHAIN SHARP CS-X
brian
   / Finally found an accurate easy method to sharpen my saw #5
Your video sold me. I just ordered 2. One for 3/8 and one for .325, and thanks thatguy. I went to the site from your link to make sure I got the right file sizes. Got them from Amazon which was the best deal I could find.
   / Finally found an accurate easy method to sharpen my saw #6
What I do is hand file a stroke or two after every 2nd fuel refill.
Makes a word of difference and generates nice long chips with fast cutting.
Only if I nick on stone or sand do I resort to mechanical grinding.
I also like to keep my files dry and clean for maximum performance.
Rust dulls them and oily files simply don't perform well.
On the other hand a well treated file really extends a pricey chain's life.
LOL, I got lucky 3-4 years back and bought a couple doz files at a yard sale for $1.00 each. Good quality to boot!.
I do have an 'el cheepo' electric grinder for those really mangled chains that need a real tune up but rarely use it.
Must add that occasional trimming of the rakers is as important as touching up the teeth. For that you want a 10-12" single cut mill bastard file, couple of strokes every now and then, not too much as you will take a bigger bite than your saw can handle.
Another thing to consider is that soaking your spare chains in oil is a good thing to preserve them. (bagging them in plastic with an ounce or two of oil is good)
   / Finally found an accurate easy method to sharpen my saw #7
I found that video and the operation of the sharper very clunky. I touch them up with the proper files when the chips become sawdust. Sometimes, I use a stone with a dremel.
   / Finally found an accurate easy method to sharpen my saw #8
++1. I also have the Stihl sharpener and agree with the OP. Takes only 5 minutes in the field and the chain is almost factory sharp.
   / Finally found an accurate easy method to sharpen my saw #9
I'll watch the video again, maybe I missed something.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
John Deere 443 4 Row Corn Head (A50774)
John Deere 443 4...
New Holland 273 Square Baler (A50774)
New Holland 273...
2012 WABASH 53FT DRY VAN TRAILER (A52141)
2012 WABASH 53FT...
