Finally broke the FECON
   / Finally broke the FECON #1
QwikDraw
Platinum Member
North East
Timber King TK711
Well I broke everything else it was just a matter of time. I was backing up and a 3-4 inch tree caught the edge of the fecon and was pulled over. It leaned on my case drain couplers and snapped the end of the male fitting off inside the female. There was no spraying since the case drain closed so I thought no big deal, until I got out and saw all the hydraulic oil coming out of the head. When the fitting closed it instantly blew the shaft seal from too much pressure.
How hard is it to change a shaft seal? I'm going to pull the motor out tomorrow and have to decide if I should change it or just bring it to the dealer?
   / Finally broke the FECON #2
If you are any kind of mechanic at all you should be able to change the seal yourself. I had many blow on my Fecon, I am a pretty proficient leak fixer after a year running the 140 for a year.
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A53843)
2004 FREIGHTLINER...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
Park Dump Trailer (A52377)
Park Dump Trailer...
