Filters for 3000-20 series
   / Filters for 3000-20 series #1
KennedyDiesel
Veteran Member
Central WI
Engine oil:
Manual calls for M811332 for engine oil filter. Number does not exist (nor does the 3720 in the dealer parts lookup /forums/images/graemlins/confused.gif) but consumer online parts (I had to request JDP list the 3720 in equipment choices and remove from position as a sub of 3520 /forums/images/graemlins/mad.gif) lists it as M806419 which I am told is the correct unit. Crossreferences to Baldwin B7216 which specs with 30 psi (higher than previous units) bypass valve.
Trans/hydraulic:
Hydro filter is correct listing as LVA 13065 and is quite spendy at $70s list /forums/images/graemlins/shocked.gif with no crossreference at this time.
Air:
Manual is correct with RE 68048 outer and RE 68049 inner and crossreferences to Baldwin RS 3549, and RS 3703 respectively.
Crossreferences should help keyword search when thread gets old...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2015 INTERNATIONAL...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
