Filtering diesel fuel from cans
   / Filtering diesel fuel from cans #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
I'm still filling 5 gal cans to fuel my tractor (ugh.) When pouring fuel yesterday, I noticed that one or more small contaminants also went in with the new fuel. Agghh. What sort of filter is recommended when fueling from a 5 gallon can into a tractor diesel tank?
   / Filtering diesel fuel from cans #2
I routinely use a "Mr Funnel".....It was $30 bucks in the size that flows 5 gallons per minute. It is suppose to remove water, dirt and debris and is unaffected by the "Power Service" additive....according to the manufacturer.
   / Filtering diesel fuel from cans #3
The Mr Funnel has to be dead level. If your filler is at an angle or theres stuff around the filler so the funnel is at an angle, it won't filter as fast and it will retain fuel in the unfiltered side, making a mess when you remove the funnel from the tank. I got one to use on my Branson which has the fuel tank filler by the step and it doesn't fit.
   / Filtering diesel fuel from cans #4
I hear you, i am thinking of getting away from cans, using an old truck fuel tank. Then I can pump it and filter it before it goes in. Also, looking at replacing my 5 gal cans and I can't stand the new alternatives.
   / Filtering diesel fuel from cans #5
I use my Mr. Funnel when fueling my tractors, although it has the drawbacks pointed out above. Unfortunately, I can't position it to work when fueling my RTV. The yellow six-gallon cans I use have built-in screens that catch debris, but are of no use in filtering out any water.
Steve
   / Filtering diesel fuel from cans #6
+ 1 on the Mr funnel. You can buy smaller diesel cans as well. I have stacks of red ones , so I was cheep and painted 2 of them yellow so it is easier for the Mrs. to handle.
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2016 Club Car Carryall 500 (A50121)
2016 Club Car...
2022 Deere 317G (A50120)
2022 Deere 317G...
