Filter strap wrench for John Deere
   / Filter strap wrench for John Deere #1
BloomingtonMike
Platinum Member
John Deere 3320
I was in Farm and Fleet yesterday and picked up a filter strap wrench made for John Deere. I will let you know if it works with my 3320. Anyone use this wrench - much larger diameter than the other models.
   / Filter strap wrench for John Deere #2
I have a wrench bought at NAPA. It has like 3 fingers that tighten against the filter. On my little 4010, it's about the only thing that you can get onto the filter. Have a chain wrench, but it's a royal pain to snake it up around the filter. The NAPA wrench works great.
I don't know why they don't put a hex head on the end of the filter casing. In the past, I've seen filters done this way on some cars.
Ralph
   / Filter strap wrench for John Deere #3
Just bought the same NAPA 3 fingered wrench, great tool.
   / Filter strap wrench for John Deere #4
If you mean the 3320 hydraulic filter, the cap is 4.5" in diameter. I got a large filter band wrench at VIP auto designed for Cummins/Detroit filters which worked. A standard oil filter wrench will not do it.
If you mean the 3320 oil filter, a standard oil filter wrench will do.
   / Filter strap wrench for John Deere #5
Bloomington mike,
If you mean the one where you use a 1/2 drive to turn the square which is attached to the strap, then I suspect you will agree with me after using it, it's AWESOME. I picked that strap up at a Deere shop some 3-years ago, and it's one handy item.
320 Gal Fuel Tank (A53316)
320 Gal Fuel Tank...
2006 Isuzu NPR-HD Landscape Dump Truck (A55788)
2006 Isuzu NPR-HD...
Hydraulic Power Unit S/A Towable Pump (A55787)
Hydraulic Power...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
1998 Volvo VN T/A Dump Truck (A55788)
1998 Volvo VN T/A...
