Filter For Hydraulics
   / Filter For Hydraulics #1
Momboy007
San Diego
Jinma 304
Hello All,
I have yet another question concerning my Jinma 304?
I have a Japanese loader installed on my tractor, I think it called an AG3????, anyhow, I have a filter near the starter on the right hand side of the motor, Do I still need to clean out a mesh filter somewhere, or should I remove it??
Thanks all in advance,
Rick
   / Filter For Hydraulics #2
I would guess that if you have a spin on strainer can on the pump suction line, that you do not have a suction strainer in the tank.
I am not familliar with exactly where your hydraulic system draws fluid from the 3PH lift box. The 200 series draws fluid out of the top of the box and there is a 3 bolt flange plate on the top front corner. There is a pipe fitting and plumbing that runs forward to the pump. Attached to the bottom of the plate is a suction pipe with a strainer (brass screen)attached. I know some of the larger machines draw their fluid from the side of the box behind a similar plate and require that you drain the resovoir to remove that plate.
RYOBI 18V BRUSHLESS ELECTRIC 20" PUSH MOWRE (A51248)
RYOBI 18V...
KMC 6R 36" PEANUT INVERTOR 3PT (A51247)
KMC 6R 36" PEANUT...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
