Filter cross reference with Wix for LX410
   / Filter cross reference with Wix for LX410 #1
NHSawyer
Bronze Member
Southern NH
Cub Cadet/Yanmar LX410
Hi Folks,
Has anyone here figured out the cross reference numbers for the oil and fuel filters from those used on a LX410 between Yanmar and Wix. On the Wix web site they do not list the LX410. To get the engine number from the machine you need to lift the hood crawl up there with your head between the hood and engine. I thought someone might have done it.
Ok I found the engine model in the manual and checked the Wix web site. It listed engines but not the one in either the LX410 or LX450.
Just spoke to the dealer and the a set of oil and fuel filters (1 each) is $20.47 for the set so I guess it is reasonable. They also told me the air filter had come down to $90 from $110.
   / Filter cross reference with Wix for LX410 #3
According to the parts manual the part number for the oil filter is CY-129150-35153. If you do a web search on 129150-35153 you'll see that this filter is used on numerous Yanmar motors. According to a couple of web pages,
YANMAR |
and
Hanlec Power Solutions | Shop | Viewing Oil Filter 129150-35153
What's weird is that if you search Yanmar's parts search, it can't find part number 129150-35153.
According to the following websites:
http://www.cruisersforum.com/forums/f54/yanmar-oil-filter-97294.html
and
Cross reference Yanmar 129150-35153 oil filter to Fram and NAPA
It seems that the Yanmar part number crosses to
Wix#57356 or Napa #7356
but if you enter in the Yanmar part number on WIX Filters - Products Catalog Home, the Wix part numbers that come up are the following:
51334
51334XP
There is a Fram reference on one of the web pages that I came across but when you search Fram's competitor cross reference, nothing comes up.
FRAM - Application Look-up
So I'm not really sure which Wix/Nape filter is a cross reference. Most dealers will ship directly to your house if you're looking for convenience. I'm not sure what the difference in price wise is though. From what NHSawyer is saying about the Oil and Fuel filter costing $20.47, that seams like a pretty good price.
It's always good to compare the sizes of the filter and that the rubber seal matches up as you wouldn't want to put an oil filter on that doesn't seal properly.
Thanks,
Greg
Thanks, Greg that was an informative post.
I figure the $20.47 is a decent price for the pair of filters.
   / Filter cross reference with Wix for LX410 #5
FRAM 3593A or Purolator L14459. I bought my new LX410 June 2014 and love it. It has only 20 hrs; I purchased a Yanmar replacement filter from the dealer intending to change the oil at 30 hrs ahead of the 50 hour service for added break in protection. I made an imprint mold of the filter face and took that to Walmart; I had a gray market Mitsubishi tractor that took a FRAM 3593A so that is the first I tried and it fit perfectly too; cross referenced to get the Purolator #. I studied the internal makeup of each filter and determined the Purolator had a more durable design with backflow valve to prevent dry starts. So, my plan is to use the under $4 Purolator at 30 hours, then restort back to the $8 Yanmar filter at 50 hrs (reason: have to take it 45 miles to the dealer for a warranty item anyway (temp gauge inoperable), so will let them do the 50 hrs service). Thereafter, I may use Purolators for the convenience of a local vice remote purchase.
   / Filter cross reference with Wix for LX410 #6
thporter, Thanks for the information. Looking on FRAM's website, it looks like the 3593A cross references to a bunch of filters.
FRAM Part Number PH3593A Details
Under Yanmar I don't see the filter # 129150-35153 listed, but I do see the following numbers:
129150-35150
129150-35151
129150-35152
Looking under Komatsu, I do see YM129150-35153 listed, which I would assume it's the same filter.
   / Filter cross reference with Wix for LX410 #7
FWIW. I've been using a Fram 3593A for the last 6 Yrs. on a Late 70's Yanmar Ym2000. Not a problem with them at all. I actually seen the Fram on a CL. Pic. on a used Tractor at a Yanmar Dealer and asked for the Part#.. 3.75$ at Wally's World. 8.00$+ shipping a filter from a Yanmar parts dealer was hard to justify.
   / Filter cross reference with Wix for LX410 #8
Both the fuel and oil filters use the same 20X1.5 MM thread, this should be the same on most Yanmars that take spin-on filters.
I order most of my filters through Fleetfilter.com and get the $125 order discount:
NAPA 1334 Oil Filter: $4.35
NAPA 3399 10 micron fuel filter: $9.62
So yeah, $20 bucks for both is not bad at all. I'll pick up a pair the next time at my dealer. It never hurts to have a spare set of filters, or two, and having the OEM brand CYA for warranty issues.
   / Filter cross reference with Wix for LX410 #9
Glad to find this post! Was planning to do the 50hr service on the YT359 today, wife stopped by the dealer and picked up the filters last week for me. I drained oil and pulled filter off and when I took the oil filter out of the bag it was not even close to correct. I'll check the numbers later and see what this $80 filter they sold her is, it's not the hydraulic filter as she picked up one of those too.
Dealer closed at noon, but was able to track down a Wix at O'Rielly
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
GORMAN RUPP 4 TRANSFER PUMP (A50854)
GORMAN RUPP 4...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
1991 Gmc Top Kick Dump Truck (A50514)
1991 Gmc Top Kick...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2005 Sterling Acterra Tender Truck (A51039)
2005 Sterling...
